Viper RC -
#3766
That is kind of a loaded question, but I can do the best I can to explain what the two settings do.
Both settings are associated with the Acceleration Boost settings in the VTX series speed controls.
For example, if your settings were:
Acceleration Boost Max Advance Timing: 30 Deg
Start RPM: 7500RPM
Finish RPM: 14000RPM
What these settings would do is start applying the additional timing when the motor reaches 7500RPM (it would add 1 deg of timing) and then gradually apply the 30 deg of timing once the motor reaches 14000RPM.
The relationship of the numbers will have allot to do with how the motor "feels". For Example:
Lowering the start RPM can give you more "punch" at lower rpm.
Lowering the Finish RPM so that it is close to the Start RPM will make the car feel like it has allot of "snap" in the mid range power.
Raising the Finish RPM will apply the timing more gradually and may be needed if racing on low traction surfaces.
You have to be smart and do some testing to apply how the settings feel to your car, your driving style, your motor, your gearing, traction, etc.....
Also be mindful that when applying the timing aggressively (lower RPM settings) can make it easy to overheat the ESC or motor. Remember, heat is the result of applying too much timing at too low of a RPM.
Start RPM: 7500RPM
#3767
I believe the majority that beta tested were running them in SCTE's since viper wanted a system that would stand up to the weight of that truck. As I've stated before the system to me is just as raceable as my tekin pro 4600kv system was so I think youll have plenty of power.
#3768
#3769
Congrats to Viper Team Driver Gabriel Galeano!!!
Date: Feb 4, 2012
Track: The TRACK, Maryland
Event: ROAR Region 2
TQ – 1st Place A Main 2wd Modified – Gabriel Galeano
2nd Place A Main Modified Short Course – Gabriel
Gabriel dominated the 2WD buggy class leading the way with Viper VTX10R ESC paired with a 7.5 VST motor. Smooth power delivery and loads of power, Gabriel took over the checkered flag proving that Viper will be a force at the up coming ROAR Nationals 2012. Good driving and congrats Gabriel.
Date: Feb 4, 2012
#3770
Also, what is the can length of the 550 motors?
#3771
is this product just for firm ware updates or does it do like the tekin hotwire and make settings as well...
http://www.amainhobbies.com/product_...00mm-USB-Cable
thanks i have the new 5150 system hence the reason for asking
#3772
#3773
#3775
So can someone help me understand what reasoning would be to pick either the 4500 or the 5150 copperhead for a SCTE?
The 5150 is faster but what the hell does that mean? it obviously turns more RPMS but how does that factor into choosing which one? Does the 4500 have more torque and acceleration?
#3776
#3778
my experience with motors made for 4x4SC is that the higher kv motors have a smoother feel. it's a broader powerband. it will have more top end obviously, but will lack the low end grunt of the lower kv motor. i don't know if this holds true for the copperhead line as i've only run the 4500. i can say that the 4500 system is very nice in the SCTE. for me, the 4500 would make more sense as it's more in line with the pinion options i already have (13-18). if i had more of a 11-15 pinion selection, i'd go with the 5150. if pinion selection doesn't come into play, then it would go to track conditions. if you run on a larger track with a long straightaway and jumps with long run ups, i'd go with the 5150. if the track is smaller with bigger jumps and smaller run ups, i'd go with the 4500.
#3779
The efficiency also translates into lower temps, but being able to predict what temps will be seen on the esc and motor is impossible. Gearing, track conditions, traction, air temp, gearing, vehicle, ESC settings, etc.... all contribute to temps
#3780
Allot of the Viper dealers will update any of your esc's for you if you bring it in, and many of our team drivers have them and should be more than happy to update them if they happen to have their laptop/PcLink with them at the track. Viper can also update the firmware if you send it in.
The ProGauge is used for changing the settings in the profiles in the ESC's. We have found that one of the most appealing features of the Viper speed controls is the fact that one does not have to carry a laptop to the track with them. The ProGauge covers every function in all the speed controls, and is small enough to carry in your pocket. Many times I have gone to a qualifying heat and have seen the track has changed (it is dryer/wetter than before, rougher, etc....) and have made simple changes to the punch and or timing settings right at the side of the track during hot laps. If you are strapped to a PC, you have to go to the pits, start the computer, etc....... With the ProGague it takes seconds.
Viper has been working on V-Link, a PC based software that would allow one to change settings in the VTX line of speed controls, but it will not have any more adjustability than the ProGauge does. A release date is not known at this time though.
4Likes
