Viper RC -
#2716
Can I get a link to where you have the esc setups? Im gonna mess around with mine later today. I have the 10r esc for 4x4 sc or list it for me. Thanks! Got my escs from you on friday and just put it in yesterday and runs awesome!
#2717
Try these for settings.
VST5.5XL- Short Course 4wd Settings
VTX10R-Profile #2
Brake strength 80%
Brake PWM freq 8000Hz
Brake curve linear
Neutral Drag brake 10%
THROTTLE PWM freq 9600Hz
Throttle punch 20%-30%
Throttle curve linear
Deadband middle
No timing - default
No motor protection
Esc protection 240 degrees.
#2718
i see now how you did it , thanks bat , i'll pass that to the rest of the viper team in my area
#2719
Also PPL when soldering sip the Monster/Red Bull. I had one on the way home from work and by the time i sat down to solder I had such Bad Crack Hands, (horrible shaking) I must have burnt my fingers a million times plus one major one
no more "monster" soldering for me.
#2720
Perfect!! Glad there is no issues...
VTX10R-Profile #2
Brake strength 80%
Brake curve linear
Deadband middle
No timing - default
No motor protection
VTX10R-Profile #2
Brake strength 80%
Brake curve linear
Deadband middle
No timing - default
No motor protection
I saw the pic of the esc
Im not sure if its been asked, but will one of the esc's be sensored and non? Is that copperhead better then the 10r?
#2721
wish i would have saw this three hours ago. I did a inline bullet. This looks much more trick.
Copperhead is sensorless only and comes with a motor. The Copperhead is a different design, more focus on bashing and club racers. I've been running the 3900kv VX4 and Copperhead in my SCTe the last month, it's been outstanding. And for $150 bucks for the entire system, you can't go wrong. It has the same quality feel as the VTX's.
#2722
No problem!
LOL, I know exactly what you mean.
Ha ha at least someone knows where to look.
It looks sweet plus has a fan built on it which woulf definitely help cooling the esc down, especially how i keep heating them up and blowin caps.
#2723
I am having a very wierd issue regarding the site. I can't view the forum or site through my PC or iphone at home. If I switch my iphone to 3G I can. That tells me that somehow my router is blocking the site. I have no idea how it happened or how to fix it. I upgraded firmware on the router and reset it with no luck.
Edit: What's really strange is that every other site I frequent plus a few I have randomly tried out work fine.
#2724
#2725
I received a PM asking me to post up my settings for a VST 7.5 in my X - 6 Squared 2wd buggy. Since this is the motor I run most often I figured I would post away!
With the power of the VST 7.5 I found I did not need the acceleration boost, though I still use the top speed timing advance. What's important to remember is that even when the acceleration boost is off (set to 0 degrees), the finish rpm still influences when the top speed timing kicks in.
Here's my VTX10 set-up for a VST 7.5.
Geared down 1 tooth from the VST 8.5; so running a 21/81 for a 10.02:1 FDR
Brake strength 85%, Frequency 4000 Hz, Curve -Exp2
Throttle punch 100%, Frequency 9600 Hz, Curve Linear
Deadband Narrow
Drag Brake 8%, Dynamic Brake 0%/disabled
Acceleration Boost: start 6000 rpm, finish 15000 rpm, max timing 0*
Top Speed Timing: slew rate 1*/1000 rpm, max timing 20*
I've attached a set-up sheet again. This set-up has more drive out of the corners compared to the VST 8.5 set-up I posted yesterday, mostly due to the more powerful motor. Still very good mid and high end performance. The settings I play with most often are the drag brake % (switch between 7 and 8% mostly), the acceleration boost finish rpm (the lower setting the sooner the top speed timing kicks in; don't go below about 12000 or you'll start to get 'turbo lag'), and the top speed max timing: higher is more overall power but hotter temperatures (28~30 is about as high as you want to go).
As always, let me know if you have any questions I can help with!
Deadband Narrow
#2728
I'm thinking about ordering a VTX10 for my pan car (RC10R5) and am wondering if this ESC supports 1 cell lipos? I'm looking throught the specs and I only see a blurb about 2-3 cell lipos. Does this ESC support 1 cell lipos with lipo cut-off etc? I run mostly Tekin ESCs at the moment but I suspect their low BECs are causing me brown-out issues when combined with my digital servos. I wanted to try a Viper ESC to see if I like them a bit better. Also, can yo program the Viper ESC without the computer interface?
Thanks . . . Matt
Thanks . . . Matt
#2729
Hi , I`ve been running Tekin for years and been wanting to try Viper for a while now . I like the features and the fact that I wouldn`t have to drag my laptop to the track .
Will the VTX10 handle a 4wd buggy ?
4Likes
