Like Tree4Likes
Viper RC -
Old 01-19-2016 | 11:52 PM
  #12001
nwv327's Avatar
Thumbs up
nwv327 is offline
Old 01-20-2016 | 07:41 AM
  #12002
Cain's Avatar
Tech Legend
for the old school 1/10 540 motors, was there a sweet spot for gearing and timing the 17.5?
I got one here that actually works quite well for the stock class even against newer motors, at the track I ran at recently, indoor carpet offroad it comes off like cold on a durango dex210 with a 69T / 33T gearing setup running max timing.
I am curious if I should go even bigger with the pinion size and if there is a certain timing value that works better.
Considering what the motor is though, works well.
Also, for an older motor option that I hear is still good, Amain has the Black editions for $50, not bad for anew motor.
Cain is offline
Old 01-20-2016 | 10:58 AM
  #12003
Davidka's Avatar
It's always worth experimenting to see if there's more speed in it, but if it's fast and it runs cool, there's no reason to chase heat, that just makes the motor fade later in runs.
Try adding timing, see what that does. If it gets hotter and not faster, turn the timing back and add gear and see if it'll pull it.
Both are easy changes to make and done one at a time, neither should mess up a run at the track.
Davidka is offline
Old 01-20-2016 | 12:44 PM
  #12004
Cain's Avatar
Tech Legend
last race was getting pulled towards the end of the straight by some newer motors, but again, still cold.
I do have a motor checker of sorts so I'll give it a look and see, just curious if anyone had some tips from there times with the motors till I move to something else.
Cain is offline
Old 01-21-2016 | 06:20 AM
  #12005
nwv327's Avatar
Just curious if anyone has that link to the viper software update, not getting a response from the others
nwv327 is offline
Old 01-21-2016 | 06:49 AM
  #12006
Cain's Avatar
Tech Legend
which software do you need?
Cain is offline
Old 01-21-2016 | 10:48 AM
  #12007
nwv327's Avatar
The latest update apparently, i bought my esc/motor back in 2012/2013 and used it for a hand full of races before putting it on my shelf while i was gone for a few years. My instruction booklet says i have the A55+ firmware
nwv327 is offline
Old 01-21-2016 | 10:58 AM
  #12008
Jim Hustins's Avatar
Do you have a ProGauge or EZ-link? If so when you plug it in it will confirm what firmware you have on it. I will message Nick to send you the link if you don't have the newest one.
Jim Hustins is offline
Old 01-21-2016 | 01:18 PM
  #12009
nwv327's Avatar
I have the ez link ill dbl check the firmware
nwv327 is offline
Old 01-21-2016 | 01:29 PM
  #12010
nwv327's Avatar
Yeah when i power on the esc the ez link says "VTX10R profile 1 A55"
nwv327 is offline
Old 01-21-2016 | 01:30 PM
  #12011
nwv327's Avatar
Id post the pic i took if it would allow me to upload it from my cell...
nwv327 is offline
Old 01-21-2016 | 02:29 PM
  #12012
Cain's Avatar
Tech Legend
shoot me a msg with your email address.
Cain is offline
Old 01-21-2016 | 11:18 PM
  #12013
nikos2002's Avatar
Check you PM.
nikos2002 is offline
Old 01-22-2016 | 06:24 AM
  #12014
tedstryker's Avatar
Company is no longer in business so why have this thread opened?Nick just leave your email for people looking for help.
tedstryker is offline
Old 01-22-2016 | 07:30 AM
  #12015
bds81175's Avatar
Moderator
Because plenty of us are still running Viper products and Nick shouldn't have to leave his email on here. Nick also isn't the owner of the thread.
bds81175 is offline
