Like Tree4Likes
Viper RC -
Old 11-24-2014 | 08:46 AM
  #11086
Never mind see my question was answered a couple post up.
micrors4guy is offline
Old 11-24-2014 | 11:53 AM
  #11087
nikos2002's Avatar
Apologies -- don't see the question -- can you re-post or PM me directly.
nikos2002 is offline
Old 11-24-2014 | 11:55 AM
  #11088
It was nothing you missed. I asked a question that was inline with an answer to cain's question about the vf4 motors.
Old 11-24-2014 | 12:16 PM
  #11089
Cain's Avatar
Tech Legend
pretty sweet deal on viper gear at amain right now, especially with a 10% additional off of your purchase.
Cain is offline
Old 11-24-2014 | 12:31 PM
  #11090
Motorman007's Avatar
This will be for Oval Street Stock.
Vector X12 Brushless StockSpec 13.5
RPM 21.960
Power 241W
Magnet material Sintered 12.45mm
Specific rpm per volt, kV 3.050
Efficiency 93%
Speedo suggestion SXX StockSpec Brushless (#80910)
Want to add boost and time.
I see that start rpm would be 5856
Finish rpm will be 19520
Max advanced timing should be what?
Then Top speed timing ?
Max advanced timing?
This will be going into a B4.2 Tran is 2.6
2.6 internal gear ratio
26 pinion
Spur 84
2c pack
3050kv
Tire 83mm
Final ratio 8.4
25620 rpm
Model speed 30mph
What will get more power looking for a little more pop out of the turn 2 and 4.
Motorman007 is offline
Old 11-24-2014 | 04:33 PM
  #11091
Sale on orange edition vtx10r!!!! jeeze thats actually a good price.
RBraswell is offline
Old 11-24-2014 | 06:23 PM
  #11092
spamager's Avatar
nick -
had some funky things w the b5 viper 10black yesterday during racing.
out of 6 heats I cut out 4 of them.
curious if the esc is able to help me troubleshoot.
each time wasn't during any hard landing etc. two times and practice before racing had no issue. know that at least two different batteries were used during cut offs. one other battery that was used (one of jays) let me run full races twice.
at first I thought maybe sensor wire, and replaced after 3rd time.
symptoms: on flat of track, car just shut off. pretty sure each time the F/R lights would be solid when I pulled top (which is programming mode?) and steering would work, no throttle. twice in this scenario when I pressed throttle again and paid attention - f/r started blinking back and forth - which is motor error detection.
shut esc off, back on and car would run. but then happen again. couldn't do testing because races were running all day.
after second time I noticed the f/r start blinking on additional throttle pull, I changed sensor wire. used jays battery and got full race.(race 4).
race 5 went to battery that was fully charged but hadn't been used yet and it happened again.
race 6 switched to jays battery and got full race no issue.
I'm befuddled. race 6 would def have set it off if it was actual motor issue or some bad connection, as my 9 year old was racing which is a little more stress on the car.
recommendations? the sitting in programming mode two times it happened / then switching to motor error after hitting throttle one more time has me confused (the other two times the marshal tried to unplug battery replug so I'm not sure what state it was in then).
batteries it happened w were a peak 90c 4000 and a glacier 60c 4200. I can say that jays battery was super snug connections, but haven't had issues before w these batteries.
spamager is offline
Old 11-24-2014 | 06:54 PM
  #11093
bds81175's Avatar
Moderator
What are all your cutoff settings at? Motor temp? Lipo cutoff? ESC temp?
bds81175 is offline
Old 11-24-2014 | 06:56 PM
  #11094
bds81175's Avatar
Moderator
Also, what firmware are you running?
bds81175 is offline
Old 11-24-2014 | 07:23 PM
  #11095
nikos2002's Avatar
Motorman - so there is no one clear answer when using boost. there are many variables at play.
What I would suggest is pick a starting point - try small changes to see what helps with the improvement you are look to gain.
Start RPM - 6000
Finish RPM - 16000
Acceleration Boost - 7*
Top End Timing - 5*
Slew Rate - 3
Physical timing on motor - 30*
-- Never let timing (Acceleration, Top End, Physical) go over 60*
-- need more acceleration off corner = raise Acceleration boost, or lower Start RPM
-- need more top end = raise Top End Timing, or Lower Finish RPM
-- slew rate is speed at which Top End Timing "hits", don't need to go higher that won't feel difference, but will cause esc heat.
Especially when starting this process - stop and check temps on esc, but motor more important. Adding timing can add speed but will add heat as well. Don't automatically try and put in 25* of timing - chances are you'll damage something. Take little steps and see how it reacts.
Old 11-24-2014 | 07:35 PM
  #11096
nikos2002's Avatar
spamager -- if the system shut down with F and R flashing alternatively that is an electrical short detected outside the speed control. Either in the motor, motor sensor, or connection. Connection can be to battery (bullet connectors or plug), any wiring that has been soldered (cold solder joint), on either motor or battery - causes an arc, which speed control detects as a short.
It is possible this happens with a battery as well. I saw a team driver, tell me 3 speedo were bad, borrowed a SP, then bought a HW -- all had issues. Put in a different battery, everything worked. These systems we use are actually a lot more complicated than some like to think, there are a lot a variables.
Things to try:
-- different motor = rule out its a motor or motor sensor
-- different sensor cable = rule out its a cable connection issue
-- re-flow solder joints to any part you soldered, check factory joints to make sure wires are not frayed or cut
-- try different battery and/or check connections are clean (use q-tip to make sure not dirt or debris is in tube/connection)
Try to notice if you loose power if you still have steering or if the light on your receiver is still on. If no steering or light - that is disconnect from the battery unit will only turn back on if you tell it.
You can always PM me or email me at [email protected] if you have more questions
Old 11-24-2014 | 08:34 PM
  #11097
spamager's Avatar
bds good q's. and everything was hand touchable.. lipo is at 6 and other temps wasn't anywhere near.
nick - the bullets we used originally for battery insert aren't the solid ones.
and now u mentioned it one of the times the amb wasn't on/ car totally off. ok, gonna go through it. I'm getting suspect of the battery connections.. I'll let you know what we find.
thanks again
spamager is offline
Old 11-24-2014 | 08:45 PM
  #11098
Things to try:
Completely what I saw on the weekend. One of my battery leads (although still mechanically connected) had frayed at the bullet connector and the car was cutting out at odd times. Resoldered the joint and hey presto!
Loving the Viper ESCs. I've got 2 VTX8s and 4 VTX10R-BEs and love how tunable the esc is in terms of feel - you can have it super smooth or super aggressive!
My SpeedPassions and HobbyWings can move out of the way!
WagwanBumba is offline
Old 11-25-2014 | 03:31 AM
  #11099
boborc's Avatar
Why is Amain givin away viper stuff
boborc is offline
Old 11-25-2014 | 05:47 AM
  #11100
nikos2002's Avatar
Only saw one item on sale -- glad they included us -- gives us some recognition. Hope we make some more friends!!
