Like Tree4Likes
Viper RC -
Old 04-03-2015 | 09:06 PM
  #11686
nikos2002's Avatar
40 can be a touch on the high side for a 13.5. It does work with gearing some - if you want to run a larger pinion you might want to back off timing a little. Opposite if you want to run a smaller gear a little timing and tweak it up. I have seen it work both ways in 17.5 so pretty sure 13.5 isn't that different (don't run it often).
nikos2002 is offline
Old 04-04-2015 | 12:29 PM
  #11687
Fastforward's Avatar
Originally Posted by nikos2002
Its only been down for 2 weeks. Its needed to be fixed up for a while, some items on there have not been sold for like a year and half.
Unfortunately, our web guy is good. Not only is he costly, but also very busy.
New site will be geared towards next generation stuff. Plus be easier for me to update with race news and product tips. I don't have an exact date for when we open it back up -- because it will have the new esc info, so not til they are ready.
If you need any info on the older generation all the same info is our dealer website at www.hobbyauthority-dist or customer site at www.hobby-square.com
You can always PM me with any questions. I have some answers.
Before I retired I was responsible for a website redesign for my business unit. I can tell you what Nick is saying is true. If you are using a professional web developer and you want the functionality Nick described, it is very expensive and time consuming. Cut the guy some slack, he is trying to make things better. It's not like you can't get ahold of anybody, he is right here on rc Tech. What more could you ask for?
Fastforward is offline
Old 04-05-2015 | 08:03 PM
  #11688
TLR_TeknoRC's Avatar
TLR Teckno - I don't have an exact date yet on any new releases - it better before Christmas!!! (it will).
cheers. looking forward to it to get one! and i hope the ezlink program card is backward compatible
TLR_TeknoRC is offline
Old 04-06-2015 | 01:39 PM
  #11689
Having trouble calibrating my black edition to my transmitter.
1. Hold button for three seconds, enters calibration mode okay.
2. Pull full throttle and push button, acknowledges full throttle setting okay.
3. Push full brake and push button, then it starts chirping and won't stop until powered down.
Help!
Old 04-06-2015 | 03:22 PM
  #11690
clint's Avatar
Help!
I had a similar issue, I forgot to reverse my throttle setting in the radio..
Worth a shot..
Oh make sure your expo is at 100% max both ways as well..
clint is offline
Old 04-06-2015 | 03:30 PM
  #11691
Worth a shot..
Tried the throttle reverse but same result.
Already maxed out on travel at 125 in both directions.
Funny thing is it worked fine in a different car.
Old 04-06-2015 | 06:53 PM
  #11692
clint's Avatar
Hmmm that is weird.. try it at 100% just to see..
clint is offline
Old 04-06-2015 | 07:10 PM
  #11693
I started with epa's set at 100%. When that didn't work I moved them up to 125% which is as high as my transmitter goes. Still won't calibrate.
Old 04-06-2015 | 07:36 PM
  #11694
nikos2002's Avatar
Bob,
Biggest thing I have seen is that the speed control could be having an issue finding neutral on your radio. Each model on the radio sends out a little different signal. First thing I would try is to move throttle trim 2-3 steps in either direction and re-try the calibration.
The EPA setting for our system should be 100%, going higher can make the throttle and brake feel too soft because the throw becomes too long.
If you are still having the calibration issue after the throttle trim, you could try a different model or re-bind your receiver to transmitter. I have a 4pks radio and one of my radio models will not calibrate with the throttle at neutral, tried it with 4-5 speed controls. Move the trim slightly, no issue.
PM me if you have any other questions.
Old 04-06-2015 | 07:39 PM
  #11695
Bob,
Sounds like a couple of good suggestions there. I will try them tomorrow night.
Thank you.
Old 04-07-2015 | 10:47 AM
  #11696
I'm having trouble with my VTX10R. When I turn it on I only get a solid red light and no power to the receiver. I changed receivers still getting the same think. Anyone with ideas on what to check?
blue t is offline
Old 04-07-2015 | 11:46 AM
  #11697
Cain's Avatar
Tech Legend
sounds like what I had with my VTX8. anything change in your setup (new servo, etc).
I had to send my esc in for a replacement.
Cain is offline
Old 04-07-2015 | 11:56 AM
  #11698
No everything is the same. I know the ESC will not come on with out a signal from the radio.
blue t is offline
Old 04-07-2015 | 12:04 PM
  #11699
Cain's Avatar
Tech Legend
Have you tried the esc with it being the only thing plugged into the receiver?
What are you using specifically for gear?
Hopefully Nick may be able to provide better steps to try, but we were unable to get the ESC to "kick over" once that happened and it had to be replaced.
Cain is offline
Old 04-07-2015 | 12:12 PM
  #11700
Protek 130t servo
Vtx10R
Reds 6.5
I've been using this same setup for about 6 months now along with two other people but they have different servos. I want to say I did try it with only the esc but I will try it again tonight. I'm also going to try a receiver pack to power the receiver to see if that makes it work. If it does I'm thinking the esc has lost its output power.
blue t is offline
