Like Tree4Likes
Viper RC -
Old 03-30-2014 | 04:39 AM
  #10186
DustinH's Avatar
Do the lights on the vport respond to your radio inputs?
DustinH is offline
Old 03-30-2014 | 04:52 AM
  #10187
Drerc's Avatar
yes, and all correct !
Drerc is offline
Old 03-30-2014 | 06:09 AM
  #10188
Grasschopper's Avatar
Yes...Green light will go on when on throttle and red when on the brakes.
Edit: got those colors all wrong. When you are on the throttle the red F light illuminates. On the brakes the orange R light illuminates.
Grasschopper is offline
Old 03-30-2014 | 09:13 AM
  #10189
Drerc's Avatar
New page refresh !
Originally Posted by Drerc
Hey guys,
Last race, I did 3 laps with my new Viper VTX10R BE. Did a big jump and landed bad Had no motor reaction anymore, nothing. I could steer, but had no motor. The leds on the V-port where al Alrright, just shining like they have to, all normal. Changed sensorlead, changed motor, nothing.
is my esc really broken? How is this possible?
The BEC was set @7V with a Savox 1258TG and a Spektrum receiver, is that the fault? Voltage cut-off @6V
Hope you have a solution, they are to exspensive to just throw away
Drerc is offline
Old 03-30-2014 | 09:20 AM
  #10190
DustinH's Avatar
Are you guys both referring to the same esc? Maybe Bob or Nick will chime in. I don't know the correct answer, sorry.
DustinH is offline
Old 03-30-2014 | 09:49 AM
  #10191
LOL...nevermind. I was responding to your post, didn't realize you were asking the previous poster in order to assist him. I'm an idiot.
Old 03-30-2014 | 10:09 AM
  #10192
bds81175's Avatar
Moderator
New page refresh !
You've probably got a loose connection between the battery and ESC. The big hit can make the plugs rattle around just enough to reset the system.
bds81175 is offline
Old 03-30-2014 | 10:27 AM
  #10193
Drerc's Avatar
The servo and leds work, so that isn't possible
Drerc is offline
Old 03-30-2014 | 11:02 AM
  #10194
bds81175's Avatar
Moderator
As soon as you switch the power on for your ESC you get steering response. I've had this same problem before and it was the connection. I wonder if it's actually the ESC thinking it hit LVC.....either way, try either a new plug or going directly to the battery with your ESC and some decent bullets.
bds81175 is offline
Old 03-30-2014 | 11:09 AM
  #10195
cweb's Avatar
Need help understanding what's going on. I'm running the vtx10be/vst17.5 in my T4.2 on a carpet track on the A64 blinky setup. Started gearing @ 26/72 with motor timing @35 deg and temps were low so I geard up 1 tooth. motor temped @ mid 120's, low end was strong but needed a little more down the front straight so I uped the timing to 40. Got bout 2 min into some pracitce laps and motor power dropped off slightly then lost power, power retruned in seconds after no throttle then cut out again once throttle was applied for a few seconds. I quickly temped the motor to see if it reached the cut off but it was like 112. I talked with some team drivers and they thought it may be the sensor wire or the board is cracked, idk cause this esc/motor has only 2.5 days of run time on it. To salvage my day since I was tq(for once), I dropped the timing to 30 and disabled the motor temp cut off on the esc. after an 8 min main motor was mid 130's and esc was around 80. Can anyone shead some light on this as to what might be going on with the motor temp function?
cweb is offline
Old 03-30-2014 | 11:20 AM
  #10196
Drerc's Avatar
I solder directly onto the motor, and to the battery there is the connector indeed, do you think one of the battery connectors is broken? So he doesn't give enough power to the motor?
He gives enough power for the leds to shine and the servo to turn. After the rounds I drove him and the motor had no reaction, he was very hot for a combination with a 6.5t motor for 3 laps.
Soldered another motor, he just vibrates, but don't turns. Maybe one of the poles on the esc broken? Because of a short circuit anywhere? Could almost not believe it is the LVC, because it where 3 laps, and a fully charged lipo pack, tuned him on and off for like 6 times and no response either, not the LVC I think...
Drerc is offline
Old 03-30-2014 | 11:28 AM
  #10197
r888ghost's Avatar
Quick update: VTX10 BE is holding up awesome. Highest temp I have seen it at is 118-120 and that's 12+ minutes running. Only thing I'm confused about is if there is a way to set a lipo cut off on the esc? Accidentally ran the lipo down pretty bad (2.62 v). Yes, I understand that is low. Only was done once in its entire life. Anyhow, I know on my previous ESC the R10 Pro that it would completely shut down the car. Thanks for the help everyone.
r888ghost is offline
Old 03-30-2014 | 11:33 AM
  #10198
bds81175's Avatar
Moderator
I think you nailed it with your first sentence. I doubt the connector is broken but if it is loose enough to provide a voltage drop from the battery, the ESC may interpret that as the battery hitting low voltage. I hope I'm helping you out here.....
bds81175 is offline
Old 03-30-2014 | 11:36 AM
  #10199
bds81175's Avatar
Moderator
The default LVC with the system is 3.0 volts per cell so unless you or the previous owner turned it down it should have shut off. If you have a progauge or EZlink, the LVC is under the Protection menu.
bds81175 is offline
Old 03-30-2014 | 12:40 PM
  #10200
rcq
Hello
I am looking to order VF8 motor. Now I am running with Tekin 1900Kv. Changing Tekit to Viper brand should I buy the same KV rate? I am asking this because 1:10 viper motor have more torgue and less RPM with the same T like other brand. Is this the same and with VF8 motor?
rcq is offline
