Like Tree4Likes
Viper RC -
Old 12-25-2014 | 08:19 AM
  #11296
Cain's Avatar
Tech Legend
right now working with viper on an RMA for a couple of products, so far communication has been great. I hope to see my items back soon.
Cain is offline
Old 12-25-2014 | 07:00 PM
  #11297
I have had an issue with a motor failing during a huge race. I was furious but Nick was a champ and got me taken care of. I would be one of the loudest kittens if I didn't get my milk. Great company, great service.
RBraswell is offline
Old 12-25-2014 | 07:02 PM
  #11298
DustinH's Avatar
Yep, Nick is a pretty good guy.
DustinH is offline
Old 12-26-2014 | 01:45 AM
  #11299
Rumbler's Avatar
Unhappy Viper VF8.27 broken can
Many thanks to all! micrors4guy mtpocketsracing synap2012 i'll follow your advice, I do hope the team at Viper's will help better than my first mail...
I attach a pic of the crack, it goes around the can but the rear still holds somehow
I'm still looking for info/experience on that failure
Rumbler is offline
Old 12-26-2014 | 06:30 AM
  #11300
That is where the 2 parts of the cam are pressed together.
micrors4guy is offline
Old 12-26-2014 | 09:10 AM
  #11301
Cain's Avatar
Tech Legend
do you see any marks on the chassis from the motor? wonder if you had enough chassis flex to bump the can.
Cain is offline
Old 12-26-2014 | 11:06 AM
  #11302
Rumbler's Avatar
The chassis looks fine, just a small scratch (it's new, easy to spot), so it could have touched the can, it looks possible. Yet, it's quite a light scratch... The can would have popped just like that, on a contact with the chassis?!! It could also come from the rotor load combined with an initial weakness at the joint of the can's two parts... There must have been a weakness, otherwise I find it incredible, anyway . We have two rather big jumps, but I never had any problem of that kind so far, even though my previous motors where of a different design (Dynamite, Castle) you can also find in bashers stuff.
Have you ever had that kind of problem?
Rumbler is offline
Old 12-26-2014 | 11:38 AM
  #11303
If the chassis is hard anodized it will be harder to scratch. All it takes is the right hit at the right angle. It can happen and the viper rma should get you taken care of.
Old 12-26-2014 | 12:04 PM
  #11304
Cain's Avatar
Tech Legend
I have seen it happen on a different brand of motor in the past from chassis flex. I have personally not had it happen, knock on wood!
Cain is offline
Old 12-26-2014 | 12:43 PM
  #11305
They're here!
http://www.shopviperrc.com/ProductDe...R%2DBE%2DMOTOR
kwiksi is offline
Old 12-26-2014 | 03:00 PM
  #11306
nikos2002's Avatar
Originally Posted by mtpocketsracing
Now i remember what he said. They want way too much personal info for the rma and he didnt want to provide it. I think he said something about needing bank info
^^^ that's funny right there ^^^ guess name, address, way to contact you and what happen is too much...
nikos2002 is offline
Old 12-26-2014 | 03:03 PM
  #11307
nikos2002's Avatar
Rumbler -- you can send the unit in for warranty service - the criteria is straight forward -- original owner, within the warranty period (verified by receipt, no physical damage or damage from operation. If the failure was through our mfg process -- we replace it via warranty.
Old 12-26-2014 | 03:09 PM
  #11308
nikos2002's Avatar
Different motors will have different areas of stress. Seen bent rotor shafts, sensor units bent, bearing broken - depends on the load begin put on the motor and its design. These trucks weigh 7-8 pounds - going 20-25 mph at times, so the forces are pretty big. We'll gladly take a look at it, as with any company there are things we are looking for to see what happen.
Old 12-26-2014 | 03:17 PM
  #11309
nikos2002's Avatar
Let's get started on 2015 early!!!
New for 2015 - Viper VST Black Edition Motors
Viper R/C Solutions' VST Black Edition sensored brushless motors are your solution for smooth and efficient performance, durability, versatility and quality. Available in a wide range of turns from 3.5T to 21.5T, the Black Edition motors are with completely redesigned all aluminum structure for lighter weight (10% lighter than last gen VST), higher overall performance (15~20% more RPM than last gen VST), vented motor can, and the wide range of tuning rotors.
Available now at shopviperrc.com
Old 12-26-2014 | 03:32 PM
  #11310
bds81175's Avatar
Moderator
Sweet lookin' motors. On top of the new motors, the old motors are on sale for DIRT CHEAP!!!!!!
bds81175 is offline
