Viper RC -
#9796
#9797
Try 28/72. That is what I have run with my SC10b so the weight is about the same and the gear ratio is the same. Also, turn the motor can timing all the way up to 45. Check your motor temp and if it is still ok, move the timing a little bit more. There is a sweet spot just after 45 degrees of can timing. It will really wake up the motor.
#9798
AssocRacer, make sure you have ventilated the body properly before you do anything else. A tight fighting, unventilated body on a 4x4 buggy will burn up any ESC. I'm running a VTX10R 6.5 in my Durango DEX410 with no fan. I should probably have a fan. Higher throttle and brake frequencies will build heat in the ESC too. Check where those are set.
#9800
I have tried a range of different throttle frequencies. Haven't noticed a difference in temps from 6000 all the way to 12000. I think my esc's are all running the older software too cause I don't have control over the temp cut off. I've only had it shut down on my twice for temps.
#9801
#9802
If you purchased your Viper VTX10 series esc (VTX1, 10, 10R or BE's) after July 2012, they have a55 in them. At the time we even recalled speed controls from A Main and distributors, just to put the latest software in them.
Common ProGauge/EZ Link mistakes
- not going back to the start screen and choosing the Save option after changes.
- after changes are made, hitting ESC, instead of OK, to go back -- this will actually not register the change you made
- having the plug from the VPort to the card plugged in backwards, getting failed error on card when trying to connect.
Hope that helps everyone little more....
#9803
Company Representative
Is it safe to assume that the VTX8 is not able to be bolted into a chassis even though it comes with a template for the bolt pattern? Reason I ask is that I have my new chassis drilled for the bolt in application, but there is nothing but silicone inside so I am getting no grab from the screws.
#9805
#9806
Gary - I know there are some cars out there designed for it (which is why we did the template). But it my understand the screws you use are important - they need to grab on the metal bottom plate. Even them I would still use double sided tape or a silicone (like shoe goo) to help hold it. I put a square of double sided tape in the middle and then shoe goo around the outer edge and have not had an issue with it coming out in 1/8 or 4wd SC.
Motorman -- soon!!! We were expecting delivery this week, looks like it didn't clear customs, so look for next week.
#9807
Hi all,
Looking for ways to reduce motor temps using my vtx10be-r...I am hitting somewhere up at 200 on 5 minute winter runs, and that's with good gearing (super high grip track though).
So what will work:
1. Freq (at 12000)?
2. Punch?
3. Just dropping power below 100?
Anything else?
And yes have checked the obvious stuff like drivetrain being free etc...
So what will work:
1. Freq (at 12000)?
2. Punch?
Anything else?
#9808
Hi all,
So what will work:
1. Freq (at 12000)?
2. Punch?
Anything else?
So what will work:
1. Freq (at 12000)?
2. Punch?
Anything else?
the temp cutoff for the motor should be set round 220 to 240, since it is internal reading.
#9809
I know this has been addressed before but I've got a Hakko 888 soldering station with a 5.2mm tip and I'm trying to unsolder the stock power wires so I can lay them down a bit more.
I'm not even really putting a dent in the stock solder at 675deg for 10sec with a freshly tinned clean tip.
I'm kind of worried I'm gonna do some dmg if I put much more heat into it. Is there some black magic to get them unsoldered or do I just blast it with heat and pray for the best?
4Likes
