Viper RC -
#9766
Thanks for the replies.
#9767
Would a Savox 1251 cause my issues? The bec is set at 6.0v, but wondering if it's enough. Could I turn it up to say 6.4 without issue to make sure that brownouts aren't the issue? I've read issues of brownouts with the Savox 1251.
#9773
Thanks for the info. I am looking to replace my current LRP systems with Viper. I only run 17.5 2wd offroad buggy, and want make sure I purchase the optimum set up for this type of racing. Any further information would be greatly appreciated.
#9774
Running into a prob with my vtx8/pro 4 4600 combo. First two packs I ran. Red lights flashing on either wms of the switch. No middle green. Servo but no motor. Unplug and plug and works. Any ideas?
#9775
If you have it enabled you will need to set the cutoff to 220 to 230 as the internal temp will be higher then the external (can) temp. With my VTX10R/VST13.5 I was having the same problem. I had the protection set at 180 and if would shut off but can temp was only 120. I bumped cutoff to 230 and havn't had a problem since.
#9776
StPete - just what Riverbluff said. Reason behind this is the measurement is done on the rotor, inside the motor which has higher heat level that what is measured on the outside of the can. Same effect happens with ESC Temp cut off as well.
Rybeau40 - the servo drawing too much effects the receiver, not the speed control - when turning your servo check the light on the receiver and see if it start blinking, could mean its draining power the receiver needs to operate. Its more an issue between the servo and rx.
#9778
Huge congratulations to JP Richards for winning the 2wd Open class at the Reedy Race of Champions using a Viper VTX10R. He had 2 awesome A main races, after great rounds of qualifying, he was 1 bobble from TQ'ing the event as well. Also bumped up once (almost twice) in 4wd with a brand new car he only had for a few weeks.
Great job by Lee Martin and Travis Amzecua in the Invitation classes -- winning six rounds combined. Lee was 6th and Travis 11th out of 30 of the worlds best.
Also want to note some great sportsmanship I saw from our guys - Paul Sinclair and Travis went out several times to marshal events when they were looking for volunteers - just shows we have some qualities guys on and off the track.
#9779
Would using the proguage to turn up the bec volts help this possible issue?
#9780
Any chance we could get some set info on what the guys are running at the Reedy (esc settings and gearing)?
Jeff
4Likes
