Like Tree4Likes
Viper RC -
Old 07-16-2013 | 05:59 PM
  #8401
nikos2002's Avatar
Originally Posted by Graveyard
ok, I will try it but if that doesn't do it, what is my next move? This is a strange problem because when it happens, I still have steering...just no throttle until it is shut off and then back on.
Later
Try the settings, I would try another battery as well, borrow a friends if you can - one newer than yours to see if it makes a difference. It could be 5-6 different things or a combination of them.
nikos2002 is offline
Old 07-16-2013 | 06:29 PM
  #8402
Graveyard's Avatar
Will do... I have 3 Eco 2s 5000 from Amain and a 6600 turnigy 2s
Graveyard is offline
Old 07-16-2013 | 07:07 PM
  #8403
I have to commend Viper for their excellent warranty service, They shipped a new esc to my buddy very quickly.
Now, can anybody suggest a good PWM setting for a 6 pole 2150kv in a 1/8 buggy?
I am not sure if I need a higher number there since the switching speed has to be faster.
Feel free to chime in..
some guy is offline
Old 07-16-2013 | 09:16 PM
  #8404
double post
bring it on is offline
Old 07-16-2013 | 09:21 PM
  #8405
The Viper motor is insane. I had a 550 4600kv tenshock motor and I said no way will this Viper 540 4500kv in my caster rapture would have enough power, well I was wrong as it had so much power I had to gear it down... I can't wait to test it more this Saturday
Old 07-17-2013 | 05:34 AM
  #8406
I am looking for some progauge/v-link settings for a Truggy running 1550KV/5s.
I dont really understand what brake setting to use, along with the punch, start power and timing because I am not running a mechanical brake and it will be my heaviest vehicle. With that being said, I know it will be a lot less forgivable on the motor/speed controller. Also, what should I set the LVC at running a 5S?
I am pretty sure there are other settings someone who races would adjust, but I dont understand slew, throttle curve/rpm and all that stuff, so again, I really need a strong baseline to work off of. Any setups or advice is appreciated!
boostem is offline
Old 07-17-2013 | 08:42 AM
  #8407
nikos2002's Avatar
some guy - you will want to be in the upper portion of the range - maybe 16000 to start. More important with 6s, turn the Punch setting way down, like 30-40 to start because of the extra voltage of 6s.
boostem - what esc are us using? Start Power is a feature in our Copperhead sensorless esc, its not rated for a 5s battery. PM me with more info on what esc you are using. Thanks.
Old 07-17-2013 | 08:50 AM
  #8408
nikos2002's Avatar
European 2wd Championship update.
Lee Martin tied for TQ with Jorn Neumann with their 2 fastest runs. Lee was classified 2nd due to the 3rd run (I believe).
In the first 2 A Mains Lee and Jorn battled back and forth through both events. Lee would finish second to Jorn in both of the first 2 A Mains. In A1 by 1.8 seconds and in A2 by .5 of a second - Lee turned the fastest lap of the event trying to catch Jorn on the last lap.
Great result for Lee and the VTX10R Black Edition!! One more A final to go and then on the 4wd portion of the event.
Old 07-17-2013 | 11:09 AM
  #8409
PM sent!
I will be using a VTX8
boostem is offline
Old 07-17-2013 | 04:16 PM
  #8410
Are the 4 pole motors out yet?
astarback is offline
Old 07-17-2013 | 04:34 PM
  #8411
Thanks for responding, but I was talking about a 6 pole truggy motor.. not 6 cell
And, I have been running my punch at 70% because it still has a delay in throttle, sometimes, up the face of jumps, I'm starting to wonder if I need more capacitors.? or a higher pwm # ?
some guy is offline
Old 07-17-2013 | 06:56 PM
  #8412
We are testing them right now And so far, WOW
Old 07-18-2013 | 06:10 AM
  #8413
Anybody running the copperhead system. The $99 ones if so how are they?
Revo Dan is offline
Old 07-18-2013 | 06:15 AM
  #8414
meyankee's Avatar
I run the copperhead with the viper 4500 in my SCT410 and it is great! Very fast and smooth.
meyankee is offline
Old 07-18-2013 | 06:17 AM
  #8415
DustinH's Avatar
There are a few people around here that run them in 2wd sc and they do great. I ran one in mine most of last year and loved it.
DustinH is offline
