Viper RC -
#7654
lol. I saw a very big named driver with his cell phone out trying to figure out the blinking lights on his flow. When that didnt go well, he whipped out the manual. I think it took him 20 minutes to get his esc setup for mod, lol. I was giggling.
#7655
Haha. No blinking light counting for me. I wouldnt run anything other than viper in my 1/10 scale buggies. I used to bring a netbook to tune my other (insert brand x) esc until sand jacked the buttons up. Just waiting for a sensored 540-550 for pole motor for my tekno.
Viper, any idea when you will have a 4pole sensored motor for 4x4 sct?
#7657
The "active" braking, I think he is referring to is our Smart Brake program which acts as an programable drag brake - but setting power and rpm you want the system to brake to. Generally not used for off-road racing. But we do program a little in at default, so you do have to move the RPM setting to Disabled to "turn it off".
just chris - we see a lot of drivers set the brakes at 100 Brake Strength and 2500 Brake Freq. Then turn back Throttle EPA to control lock up. Make sure when you programmed your radio to the esc you set your end points at 100 for full throttle and full brake. If you at them higher, it will make the throttle super smooth, but the throw to the brake will be too long.
symmetricon - answer is same as 1/8 motors, they seem to be moving on same development pattern:
I should have an update next week, when I have info I am allowed to release, I will
#7658
out at our local track sunday and my boy was running his buggy and he cased one of the jumps and it shut of for a few seconds and the started back up again...never had that happen like that before thought it was a battery conection but its not that anyon have this happen to them before??
#7659
#7660
#7662
i've had something like that happen. It was a dodgy sensor wire - wire moves, electrically breaks then reconnects, ESC reboots. And if you keep pushing the throttle it takes longer to reboot as it tries to find centre.
I've also had something like that happen on a different esc - tracked it down to the bridge cable between the saddles. The birdcage was squashed and the connector was bouncing.
#7663
#7665
4Likes
