Viper RC -
#6152
when you hook up the pro gauge it will tell you the version of firmware. and you need a usb adapter to change it. I thought the pro gauge might act as the connector but it does not. But the pro gauge is super pimp. The batter checker and servo checker function are cool.
#6153
If you just bought it from Viper, it should be fine. The pro gauge does not update firmware, but when you plug it in and link it, it tells you what version your connected ESC is running. The USB connector is what you need to update.
#6154
The progauge will not update the firmware. If you run at bumps just let me know you are coming and I will bring the cable and my laptop. I will be glad to update it for any one who asks.
#6156
Guys, a couple of VTX8 questions:
1. Does it have a pluggable fan, and will replacement fans be available? Fan issues have been a real bug bear for me in 8th!
2. What do you need to be all set...if I get the esc with pro gauge is there also a pc link required for updates?
Thanks,
Dave
Thanks,
Dave
#6157
Thanks,
Dave
Thanks,
Dave
I would just get the ESC and a ProGauge, beyond that, if there are firmware updates, you do have the option of buying the PC-Link then, or they have offered doing updates at the Service Center if you ship it there (if you aren't near anyone who has one)
#6158
New qualifier track record with my Viper powered Caster buggy today. 1st 16 lap on new layout that went in last Wed. I'm running a VTX10R and 7.5. I have never been so happy with a esc and motor like the Viper stuff.
Rick Jenkins
Rick Jenkins
#6162
#6163
That is the fastest qualifier run for any class and it was 16 laps at 5 minutes and 21 sec. I had a really bad last lap as 21 sec is kinda slow. The other stuff on that board is single fast laps....I hope that helps... After I took that pic it was changed to 16-5.21
#6164
Has anybody tried the optional rotors in a 17.5 blinky setup? We had a big race over the weekend and it came up that the fast guys were using bigger rotors. The fast guys were also able to make a triple with ease and I am wondering if the bigger "torque" rotors would help.
If so, how does it effect top speed, gearing, etc?
#6165
Colin, the viper 12.5 rotor is very strong. I tried the high rpm and didn't like it in blinky. I would try gearing.. I know it sounds low but I am geared 75/29 in blinky and feel just fine with that. Loads of torque and plenty of rpm.
4Likes
