Like Tree4Likes
Viper RC -
Old 02-12-2014 | 10:42 AM
  #9901
Grasschopper's Avatar
Originally Posted by Cain
are there any issues using viper ESCs with the Speed passion line of 1/10 scale motors?
Figure I would ask as I know sometimes some ESCs have issues with some motors, so wanted to confirm.
Same question with Schurr Speed motors.
In my B4.2 and now moved to my B5 I am running a VTX10 with a SP V3 MMM 17.5 with no issues. The one suggestion that I believe is always made with non Viper motors is that you disable the motor temp protection as it may not be compatible.
Grasschopper is offline
Old 02-12-2014 | 11:05 AM
  #9902
Captcha's Avatar
I can not find anywhere where it says any motor limit on the VX1, I do enjoy my HW that I have, but I have also heard many great things about the Viper esc's.
Captcha is offline
Old 02-12-2014 | 11:06 AM
  #9903
nikos2002's Avatar
nebiforever - not quite sure what additional information you want - that's not different from what every other company puts out there. We do 3 different kv ratings - 1900, 2100, and 2700. The 1900 and 2700 are Delta winds, the 2100 is a Wye wind. Bearing sizes are 5mm x 11mm x 4mm on the bottom and standard 1/8 x 3/8 x 5/32 on the top. You can PM me for more information.
Cain - we have never had issued reports of problems using other motors with our speed controls. We have tested with all the popular brands, and some you have never heard of. We do see that there can a large difference in the sensors in how they work with our protection cut offs. But little testing can help you make sure you are comfortable with the settings.
Currently all the VTX10 models come with the "pig tail" style capacitors, even the Orange series. Its just updates we have made over the years to bring the Orange series in line with the Black Edition technology. We still sell the surface mount capacitors as an option. But the updated designs are more efficient and will produce better overall results.
The differences between the 10 and 10R series - besides a little height difference, is just that the 10R can handle lower turn motors (hence the extra height).
Right now we don't have a "blinky only" speed control, because in other parts of the world, blinky is not required, so we need units with all the options available. But our unit is also designed to help tech inspectors see that not only is the blinky mode activated. But also that the unit is in neutral at the same time, so it can be accurately checked.
nikos2002 is offline
Old 02-12-2014 | 11:08 AM
  #9904
nikos2002's Avatar
On 1s no limit, on 2s - 7.5 (all 2 pole motors only). No booster required for 1s operation.
Old 02-12-2014 | 12:11 PM
  #9905
Hmm...that's actually disappointing to me. I just sent back a VTX10 BE that went up in smoke this past weekend for trade in and I was going to say send me a VTX10 (non BE) as I prefer the top mounted caps for the clean install. There's no great place to put the cap pack in a B5.
Old 02-13-2014 | 05:58 AM
  #9906
So far so good with my new Viper speed controllers in 2wd and 4wd buggy! These controllers are both smooth yet robust! I like the program box and look forward to posting up a few set-ups for these units soon.
synap2012 is offline
Old 02-13-2014 | 06:12 AM
  #9907
VIPER REP...... I just order a vtx10be, are you saying in the post above since all vtx series come with pig-tale style caps that there are no differences between them? 10 vs. 10be & 10r vs. 10rbe
JOHNSON! is offline
Old 02-13-2014 | 09:53 AM
  #9908
nikos2002's Avatar
The orange VTX10 and VTX10 Black Edition are similar. The orange VTX10R and VTX10R Black edition are similar. Difference between 10 and 10R series, is that 10R can run lower turn motors - 10 series is limited to 7.5. Yes all will come with pigtail style capacitors. You can still purchase the surface mount capacitor for the orange series if you like, but we recommend the pigtail design.
Old 02-13-2014 | 09:58 AM
  #9909
Derry's Avatar
Is there a way to check if I have a faulty sensor unit in my VST motor? Using a volt meter or something?
Derry is offline
Old 02-13-2014 | 10:04 AM
  #9910
rob martin's Avatar
Viper in my b5..As you can see with the Viper there is plenty of room
rob martin is offline
Old 02-13-2014 | 10:08 AM
  #9911
nikos2002's Avatar
Here are to options to think about with mounting the VTX esc with the pigtail capacitors. The Black Edition pictured is actually one of Lee Martin's from the IFMAR Worlds - he just shortened the lead wires so the cap stayed right on top of the ESC. The orange VTX10R is one of my spares, I put it on the side, shortened the wires slightly (could have a little more, I am picky like that).
Its OK to shorten the wires on the capacitors, you really don't want to lengthen them, they loose efficiency at that point.
Old 02-13-2014 | 10:10 AM
  #9912
nikos2002's Avatar
There are motor checkers out there that also have a sensor test part. I would put another motor on the esc - it will let you now if the esc is OK.
Old 02-13-2014 | 10:27 AM
  #9913
Derry's Avatar
Yeah, I was just trying to avoid the hassle of motor swapping.
Derry is offline
Old 02-13-2014 | 11:40 AM
  #9914
nikos2002's Avatar
Viper R/C is proud to be the exclusive North American distributor for Xpert Servos -- check out the official R/C Tech Thread at:
http://www.rctech.net/forum/radio-el...l#post13005449
Old 02-13-2014 | 03:48 PM
  #9915
wever75's Avatar
Amain dosent Carry the viper vtx10 8.5T motor ESC combo
wever75 is offline
