Like Tree4Likes
Viper RC -
Old 07-18-2013 | 06:24 AM
  #8416
I'm getting my son a 2 wd sc and want something cheap in price but good and this sounds like its the right setup
Revo Dan is offline
Old 07-18-2013 | 06:29 AM
  #8417
DustinH's Avatar
Yes, definitely.
DustinH is offline
Old 07-18-2013 | 06:54 AM
  #8418
godofcable's Avatar
ive been using the 4500kv setup in my slash 4x4 for over a year. its been good. hard to beat it
godofcable is offline
Old 07-18-2013 | 06:57 AM
  #8419
I'm looking at the 3900 kv 540 4pole
Revo Dan is offline
Old 07-18-2013 | 07:31 AM
  #8420
I have a coppethead-r 550 4pole system for my durango desc410r. I was wondering what pinion I should start with?
Chris
chrisw is offline
Old 07-18-2013 | 04:08 PM
  #8421
weyant's Avatar
Dan...Jerry Durst that comes to Rt281 from Friendsville has one of those in his sc10 2wd and he loves it
weyant is offline
Old 07-18-2013 | 04:18 PM
  #8422
nikos2002's Avatar
chris - sorry I don't know Durango gear ratios. If you have a 4500kv gear same as anyone with a Tekin 4600. If you have the 5150, go down 1 or 2 teeth.
some guy - with a 6 pole motor, might have to drop it a little more, that 6 pole will generate some amp draw, and it pulls the battery down to LVC for split second
nikos2002 is offline
Old 07-19-2013 | 05:00 AM
  #8423
Does anyone know what the smaller plug on the pro gauge wire is called? One of the pins is messed up in mine and I don't know what to look for to find a replacement.
anr211 is offline
Old 07-19-2013 | 05:43 AM
  #8424
Wildcat1971's Avatar
contact viper for a replacement. I doubt you will find that connector on ebay
Wildcat1971 is offline
Old 07-19-2013 | 06:31 AM
  #8425
ridgerunner1's Avatar
you talking about this wire.
http://www.amainhobbies.com/product_...s-V-PORT-Cable
ridgerunner1 is offline
Old 07-19-2013 | 06:49 AM
  #8426
that is what he is looking for
Old 07-19-2013 | 08:17 AM
  #8427
Originally Posted by ridgerunner1
Perfect. Thank you!
I searched quite a bit for it before posting but never included v port in my searches.
anr211 is offline
Old 07-19-2013 | 03:13 PM
  #8428
Cool thx Brian
Revo Dan is offline
Old 07-19-2013 | 06:59 PM
  #8429
Graveyard's Avatar
Originally Posted by nikos2002
Try the settings, I would try another battery as well, borrow a friends if you can - one newer than yours to see if it makes a difference. It could be 5-6 different things or a combination of them.
Hi again,
So I tried several combinations of the suggestions I received. I change the esc setting to profile #3. Then I reduced the transmitter signal to 16.5 ms.
I ran for two afternoons going over a jump and running in grass in direct sun with a temp sensor and the body on it. Had no problems till the second day...
after jumping ten foot or so with no problems, I slowly ran over a stick laying in the yard. It was about an 1 1/2" in diameter. The esc shut down as described.
I had steering but no throttle. The f and r leds were flashing rapidly. The temps were 122 on the motor and 107 on the speed control. After letting it set for 15 seconds or so, it actually did reset itself. Do I need to exchange this? And are the ones you receive refurbished or new?
Graveyard is offline
Old 07-19-2013 | 08:38 PM
  #8430
Originally Posted by Graveyard
Hi again,
My copperhead-r does this as well. I did not read the temps and while the f and r leds were flashing but the n was solid. I let it sit for 3 min and it runs, but the problem reoccurs. What gives?
boostem is offline
