Viper RC -
#916
The temp sensor is internal on the esc and motor so there will be some variance between the outside temperature you measure and what the thermal setting triggers at. Internal temps will always be much higher. Just something to be aware of.
#917
#918
#924
I have one and another on the way, hopefully this week.
I was all excited to get it wired up the other day only to realize all I had on hand was 12g wire
Hitting the LHS tonight to grab some 14g. Then I'll bring it to life.
#925
I also prefer to use 14g wire, but if you need to use the 12g just tin the end and then clip it with a side cutter to make it smaller. I have done this many times and it works like a charm. Also for all my stock stuff I have switch to 16g. It seems that the amp draw requirements of brushless are not even close to the brushed equivalents. Wires don't get hot and it is much easier to use in tight spaces.
#930
Viper R/C Solutions
Viper R/C Solutions is proud to present the long time waiting ESC with loaded innovations and top quality, the VTX series.
Viper's VTX10 /10R electronic speed controller for 1/10-scale and 1/12-scale RC cars and trucks give you more features and innovations to make your on-road and off-road RC cars ready to run and ready to compete.
T...he revolutionary V-PORT interface lets you program settings for your ESC via VIPER ProGauge without unplugging the receiver (RX) connector. The small footprint and waterproof aluminum case fits easily anywhere in your vehicle with the maximum durability.
Stay tune, first shipment will be arriving in mid April, 2011.
From Viper's Facebook post
4Likes
