Like Tree4Likes
Viper RC -
Old 01-06-2012 | 11:02 AM
  #3496
Jtipsy's Avatar
vtx1 is stated for being more so for an onroad as the vtx10 is offroad capable.
There may be some difference there, i personally have a vtx10 and love it.
Jtipsy is offline
Old 01-06-2012 | 01:56 PM
  #3497
nikos2002's Avatar
Originally Posted by bring it on
I had a friend of mine buy the 4.5 550 and the VTX10R for his losi 4wd sc truck. He said it runs hot. 180/190 He has a 13t pinion on it. Anyone run this truck and esc combo that can help me with setup?
Rick, here is the set up listed in the set up guide from the Viper forum:
Throttle punch settings for 4wd Short Course Applications
When using the VTX10R speed control with sensored 550 motors, we recommend a setting of 30% on your throttle punch settings in 4wd SC applications.
We recommend these VTX10R settings when running 4wd SC with the VST XL 4.5 or 5.5 motors.
VTX10R-Profile #2
Brake strength: 80%
Brake PWM freq: 8000Hz
Brake curve: linear
Neutral Drag brake: 0-10%
Throttle PWM freq: 9600Hz
Throttle punch: 20%-30%
Throttle curve: Linear
Deadband: Middle
No timing: default
No motor protection
ESC protection: 240 degrees
Note* ESC Protection takes a heat reading from inside the speed control where a normal heat gun can’t take an accurate core reading.
_________________________________
You guys are all on the mark - the VTX1 has a booster for 1s use and can be used in 2s down to 6.5 motors.
nikos2002 is offline
Old 01-06-2012 | 04:32 PM
  #3498
Autocratic's Avatar
How to I change motor rotation? Do I simply swap wires or do I rotate the can like on brushed motors?
Autocratic is offline
Old 01-06-2012 | 05:20 PM
  #3499
SolderGlob's Avatar
Swapping any two wires should work.
SolderGlob is offline
Old 01-06-2012 | 06:29 PM
  #3500
idrummerboy13's Avatar
NO NO!!
Go to your radio and reverse it, what radio do you have?
and go into ur speedo's card and play with it, i dont remember but i think somebody is in there
Im am pretty sure it will fry if wires flip with sensored system, it happend to a few guys at track, wrong wires on tabs and smoke.
idrummerboy13 is offline
Old 01-06-2012 | 07:26 PM
  #3501
larlev's Avatar
Not if it's sensored...only un-censored motors can be swapped.
Go into radio or re solder wires
larlev is offline
Old 01-06-2012 | 08:37 PM
  #3502
Autocratic's Avatar
Originally Posted by idrummerboy13
NO NO!!
Radio is Spektrum DX2.0. I've had it forever. Only thing swapping in the radio does is make the trigger pull braking instead of throttle.
I've gone through all the settings in the ESC and haven't found throttle norm/rev.
If I need to swap wires, where does the ABC wires need to be on the motor?
Old 01-06-2012 | 10:08 PM
  #3503
Autocratic's Avatar
Ok, I'm stumped. VTX10R on A30 firmware.
I've gone through the ProGauge settings and nothing is related to motor rotation.
I've zeroed and recalibrated with radio trigger rev & norm. Nothing.
I've also flipped the sensor wire on the motor and that didn't change anything either.
Only thing left is swapping wires and that's going to result in a smoke storm.
So, what do I do?
Old 01-06-2012 | 10:19 PM
  #3504
Bigedmond's Avatar
So, what do I do?
Your Radio should have an option to reverse the direction. Dont mess with the wires. Reverse it in the Radio.
Bigedmond is offline
Old 01-06-2012 | 11:31 PM
  #3505
Autocratic's Avatar
There is no option in this radio that has changed the direction that the motor turns. I've gone through everything.
Old 01-06-2012 | 11:39 PM
  #3506
Bigedmond's Avatar
http://www.spektrumrc.com/ProdInfo/F...20ManualHR.pdf
Page 20 shows how to reserve the throttle channel
Old 01-06-2012 | 11:43 PM
  #3507
Autocratic's Avatar
Except that this didn't work, even after recalibration, which is what I posted above.
Old 01-07-2012 | 03:09 AM
  #3508
FLHX1550's Avatar
Originally Posted by rcgod
Viper website says vtx1 is 1-2s. Other than that are they the same?
VTX1 is 1s and 2s capable but adds the function to "up-boost" a 1s battery voltage in the receiver to run the radio system. 3.7v isn't enough to run a receiver/servo/and transponder, so the VTX1 can output 6v power to the radio system, where as the VTX10 cannot.
This is more of an on-road thing, as 1/12th scale and VTA classes run 1s Lipo.
On 2s, the VTX1 and VTX10 are pretty much the same. The VTX1 was just made to fit all on-road classes, not just 1s.
FLHX1550 is offline
Old 01-07-2012 | 09:26 AM
  #3509
Arigato's Avatar
So, what do I do?
Use your pro guage and scroll to misc. controls. Scroll down and you will find "motor direction".
Arigato is offline
Old 01-07-2012 | 12:03 PM
  #3510
I went racing last night with my Viper 7.5 powered 1/10th caster buggy, It was a BIG night as we had over 10 fast guys come up from California to race at our track. It was a night of N. Nevada VS N. Cal. LOL In mod 4wd buggy we had a full 10 in the A main. I would have qual'ed 3 or 4 if laped traffic didn't get into me and hung up on my wing. It's all good though. I qual'ed 5th. Before the main i put on a new set of clay raptors with proline foam but still had some real loose fitting rear switch and aka foam. I got some proline foam to try in some new rear tires i just got for my buggy. I just missed 22 laps by less the a sec. I took 4th place.
2wd open sc had also had a full 11 in the A main. My Viper powered 10.5 Kyosho ran great all night. I made a few to many mistakes but again it's all good. I qual'ed 4th and took 2nd in the main again missing 21 laps by less then a sec.
bring it on is offline
