Viper RC -
#3346
Ok I got my replacement back 10.5vtx10 broken inn my buggy 22 I'm very happy with this motor/esc and the pro gauge is very nice and handy..i did leave it stock for now but now I want to crank up some power a bit..where do I start ? Adjust the degree timing on the motor?how much degree?I do remove the 3 screws on the back right? Also on the pro gauge I see profile like 1/2/3/4 ect are they all the same settings? Do I adjust the degree timing on each profile?
Breaking is very smooth I would like to get more out of it..
Also motor/esc was cool not even warm due to the winter weather the indoor track is cool so it help it even more on the esc/motor/batt..
#3348
mamc24 (& Stealth) - I wonder if you guys are pulling the BEC voltage too low. I saw serval guys (using our motors, esc, and others) - have a brief esc/receptions cut off because it was pulling too much and the receiver would go into a shut down/lock up mode until the voltage recovered for the system. You may try checking the voltage cut off on the esc - or even using additional capacitors plugged into the receiver to help make sure the voltage is up. Just some late night thougts.
Nitro- sorry, I don't have experience to help point you in the right direction.
Nick/TQ
Nick/TQ
#3350
Hi Guys,
A new much larger indoor carpet track has opened in my area. I was running a 13.5 but I have a feeling this will not be enough for the new track.
I'm looking to throw in a 10.5.
Does anyone have any base line settings. It's for an RB5.
I am looking for esc settings and gearing combos.
Here is a little vid, just to give you an idea of the track size.
http://www.youtube.com/user/tsan76?o.../0/66gjlIvcLvo
Thank You
Thank You
#3351
Hi Guys,
Thank You
Thank You
#3352
I ran this past Sun with the set up previously mentioned and a 13T pin. Truck had good power through the entire band, but maybe lacking just a tick on top. Motor was barely warm if at all, after an 8 minute run. I'll be gearing up a bit next time out. Also, I didn't time it, but I'd guess I could run 10-12 minutes, maybe more on a 5200Mah 60C LiPo, much MUCH better than the previous motor.
#3353
To get more power you can check your throttle punch an make sure it's at 100% if so you can add timing on the esc or motor just watch your temps .
#3354
Hi Guys,
Thank You
Thank You
Very Nice track you have there.
#3355
ok for everyone that has pmed me her is what i use for a starting setup in 17.5,13.5 10.5 2 wd buggy classes off road i put the same stuff in alot of peoples cars over the last month or so and pretty much everyone liked it
Ok sorry it took so long but here is my 17.5 &13.5 settings blinky and open
Profile a30
Brake strenght. 100
Brake frequency. 9600
Brake curve. Lin.
Dynamic brake
Trigger rpm 9500
Max brake. 2 percent
Dynamic curve. Lin.
Drag brake. 25 percent
Throttle frequency. 4000
Th punch. 100
Th. Curve Lin.
Motor power
Acc boost.
Start 3500
Finish. 17000
Max advance tim. 25
Top speed
Slew rate. 10/0.10 sec
Max advance tim. 20
Delay. 0.10
just listen to the car down the straight and gear to have it top out 3/4 of the way down
Profile a30
Brake strenght. 100
Brake curve. Lin.
Dynamic brake
Trigger rpm 9500
Dynamic curve. Lin.
Th punch. 100
Th. Curve Lin.
Motor power
Acc boost.
Start 3500
Finish. 17000
Max advance tim. 25
Top speed
Max advance tim. 20
Delay. 0.10
#3359
For those that want a vtx1 Amain has them in stock
http://www.amainhobbies.com/product_...ESC-w-ProGauge
4Likes
