Viper RC -
#2598
The 5mm shaft R series 4 poles are going to be longer than the 3mm shaft versions. We are using the same length as the L 550's, which is shorter than the VST XL's and will not require any trimming to get the motor into the SC10 4wd.
#2599
That sounds good. I already have a pro4 on the way but I will probably just sell that and wait for a 550 4 pole then. Outdoor season is ending soon where I am anyways so I guess I can wait a little longer for those.
#2600
What do I want to gear this thing at? I have a 12 tooth on it right now.. but someone was telling me hat these are torquey motors... so have to compinsate with a 14/15ish?
I managed to finagle, grind, whittle, and sand my way in there!
#2601
I run a 14T on the 5.5 and it gets up and moves nicely and very smooth. Don't run any boost/timing on the 550's. They come stock from the factory with 30 degrees on the can. If you need more speed gear up.
#2602
It's a good system, I have been running it the last month without issues in my SCTe. I can't wait to get my hands on the R52, it's going to be a monster in the horse power department.
Nice, that is a very clean job!!! Thanks for the pictures also!
Brake strength - 80%
Brake PWM freq - 8000HZ
Brake curve - linear
Neutral drag brake - 10%
Throttle PWM freq - 9600Hz
Throttle punch - 75% - 90% depending on traction
Throttle curve - -1Expo
Deadband - middle
Stock Blinky mode
Motor temp cuttoff - Disabled
ESC protection - 200 degrees
Holeshot mode - off
Anyone think of anything else?
#2605
A friend/regional viper driver gave me these settings to start with...
Deadband - middle
Stock Blinky mode
Holeshot mode - off
Deadband - middle
Stock Blinky mode
Holeshot mode - off
VTX10R-Profile#2
Brake strength 80%
Brake PWM freq 8000HZ
Brake curve linear
Neutral drag brake 10%
Throttle PWM freq 9600Hz
Throttle punch 15%-20%
Throttle curve linear
Deadband middle
no timing- default
no motor protection
esc protection 240 degrees
#2606
#2608
This is what we at Viper recommend.
VTX10R-Profile#2
Brake strength 80%
Brake curve linear
Deadband middle
no timing- default
no motor protection
No, it's a 1/10th scale system, it's benchmarked in the SCTe so unless you are rolling a 810, I'm going to say no.
Saw the results!! You had a very short time for setup last night and did very well. Nice work!
VTX10R-Profile#2
Brake strength 80%
Brake curve linear
Deadband middle
no timing- default
no motor protection
4Likes
I got 2nd in mod 2wd.
