Viper RC -
#2447
#2449
Yesterday I ran the 1800kv motor again and result is FAIL! Mikes Hobby shop onroad and offroad track were used.
Runs too effin' hot man. 170F running half a pack is not exceptable. I had to ease on the brakes and throttle to get to 150F. Was like granny drivin' in loserville county. I had more fun driving a 1512 1400kv 4pole motor. Sensor board on the motor is toast as well. My son's 2 pole C50L 1800kv Hacker has more power/excelleration and runs way cooler. There was another Viper motor on the offroad track and that one also ran stupid hot.
Just like the LRP Vector 8 motors, these 1/8 Viper 3 slot 2 pole motors are no good for 1/8 vehicles. However they would be great motors in 2s and 3s Slashes with Turbo enabled on the esc's.
Hopefully improvements will be seen with new rotors.
#2450
#2453
See that is more like it. A decent size rotor in a 540 can motor.
I allready have a 4pole Aveox 1406 3000kv motor(5mm shaft) and it's plenty of fun on 2s. Now Viper has to offer the 5mm shaft too. Seems everybody is coming out with 4 pole 1/10 motors for a decent price.
It wasn't long ago that only Aveox and Plettenberg made 4 pole 1/10 motors for an arm and a leg.
#2454
#2455
Did a few test runs again with 0 degrees timing. Temps where much better.
Run #1 measured with Eagletree V4 150A.
Tekin RX8
0 timing
Stock brakes
4s hardcase Acepow
20T pinion
Ofna GTP 47 spur
Peak Amps 157.35A
Peak Watts 2069W
Continuous Amps 22.08A
Continuous Watts [email protected]
129F
Run #2 measured with Eagletree V4 150A.
Tekin RX8
0 timing
Stronger brakes
4s hardcase Acepow
23T pinion
Ofna GTP 47 spur
Peak Amps 162.21A
Peak Watts 2039W
Continuous Amps 27.67A
142F
So it looks like I can go up another tooth with the pinion and still be good with temps.
Tekin RX8
0 timing
Stock brakes
4s hardcase Acepow
20T pinion
Ofna GTP 47 spur
Peak Amps 157.35A
Peak Watts 2069W
129F
Tekin RX8
0 timing
Stronger brakes
4s hardcase Acepow
23T pinion
Ofna GTP 47 spur
Peak Amps 162.21A
Peak Watts 2039W
142F
#2456
Tekin RX8
0 timing
Stock brakes
4s hardcase Acepow
20T pinion
Ofna GTP 47 spur
Peak Amps 157.35A
Peak Watts 2069W
129F
Tekin RX8
0 timing
Stronger brakes
4s hardcase Acepow
23T pinion
Ofna GTP 47 spur
Peak Amps 162.21A
Peak Watts 2039W
142F
Tekin RX8
0 timing
Stock brakes
4s hardcase Acepow
20T pinion
Ofna GTP 47 spur
Peak Amps 157.35A
Peak Watts 2069W
129F
Tekin RX8
0 timing
Stronger brakes
4s hardcase Acepow
23T pinion
Ofna GTP 47 spur
Peak Amps 162.21A
Peak Watts 2039W
142F
#2457
Tekin RX8
0 timing
Stock brakes
4s hardcase Acepow
20T pinion
Ofna GTP 47 spur
Peak Amps 157.35A
Peak Watts 2069W
129F
Tekin RX8
0 timing
Stronger brakes
4s hardcase Acepow
23T pinion
Ofna GTP 47 spur
Peak Amps 162.21A
Peak Watts 2039W
142F
Tekin RX8
0 timing
Stock brakes
4s hardcase Acepow
20T pinion
Ofna GTP 47 spur
Peak Amps 157.35A
Peak Watts 2069W
129F
Tekin RX8
0 timing
Stronger brakes
4s hardcase Acepow
23T pinion
Ofna GTP 47 spur
Peak Amps 162.21A
Peak Watts 2039W
142F
#2458
Temps came down, which is a plus. But it is still a weak motor for it's size. I have been notified of a motor recall today. But I'll be holding off from sending it in. I know the motor has potential with the right rotor.
#2459
Is there any warranty coverage on the VTX10R when buying second-hand, assuming it was originally purchased in the last 365 days and the second owner had the original receipt?
#2460
4Likes
