Viper RC -
#4996
Check all the basics - make sure all wires are soldered properly. Make sure sensor wire is fully put in both motor and speed control. Unless something happen at the very end of your last run - just changing motors should not cause any power issues - or the need to re-calibrate anything.
#4998
nitro - 80º C = 176º F (sorry had to do the conversion for myself). Yes, if that is what you are reading on the outside its pushing it with temperature. Especially if run to that temperature multiple times over a two day period. We recommend to keep the temperatures below 160ºF (71ºC) for best performance. I actually like to stay around 150 unless "pushing it for a big race". Sometimes you get a little more speed if you push the temperature, but the trade off if pushing how long the motor could last.
#5000
its not really the 9º on the outside to worry about, its the higher internal temps. If it over heats too much one time, it can hurt it. Heat is the enemy with all these electronics.
#5001
I ran my B44.1 this past weekend with a VTX10R and 6.5T motor. It ran great for three or four minutes then it started cutting out. I thought it was the battery but when I put it on the charger it showed 7.8 volts. The ESC and motor were still cool to ther touch. It wasn't thermalling. I am at a loss on what this could be. Could it be the senso wire? Any help would be great.
#5003
#5005
jrj - sensor wires are finicky things with any esc - all those little wires and connections - its easy to pinch one and not see it, especially in a 4wd where wiring can be tough.
Also check your motor and esc temp cut offs - if set to low, they can shut the system down (like they are supposed to) if you hit those temps. And remember they measure internal temps, not outside temps. But sensor wire is a pretty common troublemaker as well.
spider - our 1/8 systems are still in he testing phase. We have no public time table on release. Our goal is always to make sure our customers get quality products, we would rather hold it back and make sure its right, then release with issues. There are only a few test units in the country with a select group of test drivers. That being said, I like what I see so far!!
#5009
OK Re-Binded my vehcile! Checked all the solder points! Battery is charged and good! Go to re-calibrate Full pull on trigger and lights blink with tone. Go full Reverse. Then Nuetral! Before I get any futher the truck turns on FULL FORWARD without even touching the trigger! Will not turn off!!! Have to pull trigger full pull to get it to stop then can turn it off! If I go full reverse it goes forward @ lightning speed! HELP HELP HELP!!! Sensor wires are all in place right also! Ugh... Does anyone know what is wrong???
#5010
People @ my 2 local tracks are telling me to dump them. I just bought my 2WD System a month ago. I love my 4WD Copperhead with 5150KV!!! But this VTX10 with 8.5 or 17.5 has been nothing but a hassle.
4Likes
