Viper RC -
#2327
Went indoor racing last night with my viper powered caster buggy. Ran great. Viper motor was only 130 degress after the 8 minutes main.
| + YouTube Video | |
#2328
Running a 10R with the 5.5 550 in my SC104X4 and I have had it set for speedo and motor protection, 220º and 180º respectively.
About 7 minutes into a pack, My speedo shuts down, but it is only 130º and the motor is 140º. The red light om the switch if flashing. I have to turn it off and back on and I am good for another minute or so.
I turned off all protection and same thing happened about 2 minutes into the qualifier. Motor was 125º and speedo was 110º
Any ideas?
Any ideas?
#2329
Wanted to commend viper for excellent customer service and fast turnaround. I had an issue with my 10r and sent it up for repairs after receiving an rma from the website. Viper received my esc last Monday, had a great conversation with Raegan that afternoon and on Friday I had a new unit sitting in my mailbox when I got home from work. Definitely will be buying more Viper gear in the future. Thank you again!
#2330
Any ideas?
Any ideas?
#2331
what profile are you using on the esc? I had some similar issues when I first got my 10r and I run the 4.5 tekin in my sc104x4. Truck would shut down pretty quick after stating a run. Make sure you are running in stock mode and not mod mode and disable the motor temp protection since the tekin motor does not have a temp sensor onboard. Weylin tipped me off to this and since I made the changes it was running like a champ. Also take a look back thru the thread, Raegan has a pretty solid esc setup that I plugged into my 10r that was super smooth. Good luck.
100% punch
linear curve
8000hz pwm
narrow deadband
10% drag brake
5% dynamic, 11,000rpm
race stock mode
6v bec
85-100% brake strength
linear brake curve
8000hz brake pwm
This was the setup provided by a friend through Weylin.
#2332
Sorry...i must have read your post wrong. Thought you said you had a tekin motor. I was running that same setup in the esc when I first got it, seemed to run fine? My temps were good. What gearing are you running
#2333
I went racing out door today. Qual'ed 2nd in e-truggy."Viper 2200kv" Finished 1st when i pulled off, qual'ed 3rd in buggy"2050kv" and was running 1st for awhile. You can see in the video I was beating Josh Pease until the 3:20 mark and then at the 3:30 mark i get hit by 3rd place driver and then i ran in 3rd until my battery unplugged.
Viper motors ran great as you will see in the video
Viper motors ran great as you will see in the video| + YouTube Video | |
#2336
#2337
I just installed the viper esc and tekin 4.5 550 can motor . Having huge issues with motor heating up . I'm running a 15 tooth pinion and all the tracks I run on are bigger outside 8th scale tracks . Not sure if the motor is getting hot because of gearing or esc settings !? After 4-5 minutes running, the esc will shut the motor down ,temps are around 200 . Hoping someone can give me some pointers , I know saladfork uses the viper esc any tips salad ??
Drivetrain is smooth and gear mesh was good as well .
#2339
SAME FOR 5.5
Hope this helps.....
4Likes
