Like Tree4Likes
Viper RC -
Old 05-19-2011 | 12:33 PM
  #1576
smokinu's Avatar
Originally Posted by mcheroke
I was finally able to get out to the "track" tonight with the sc10 4x4 and my new 10R. (We have a private 140 x 60 track we do testing and practice on every Wednesday night). I was amazed at how smooth the 10R is but I ran into some problems that maybe you guys have some insight with? First off here is the gear I am running with. I am running the 10R with a Tekin sc4x 4.5 550, Airtronics m11x radio (calibrated to esc per esc instructions) , Savox 1267 servo, and as for batteries I have 2 Fantom 5000 40c's and 1 Fantom 5600 50c (quality batteries). I ran 4 packs thru the truck and the problem I am running into is that my truck was shutting down after less than 5 minutes of run time. I have a blinking red light on my on/off switch. Trying to troubleshoot it tonight I wasn't able to come up with anything.Here's what I have my esc set with according to the proguage:
- run mode is set to RACE MODIFIED
- Profile 1 selected as you suggested
- everything else left at default setting
I have the truck geared to what the manual has as a starting point (62/12 13.28 fdr). When the truck shuts down the servo is still operating so my first guess would be that either the ESC or the motor has gone into thermal protection. I took temps as I pulled the truck off the track and the motor was coming off around 150-160 and the esc was between 130 and 150. According to the progauge my motor shutoff is at 190 and esc is 220 so I would think I was still ok in terms of temps. After each run I allowed everything to cool down to ambient temperature. I thought it could be the servo? That savox 1267 is a beast so I increased my sbec to 7.0v (servo is rated up to 7.4v) but this didn't seem to do anything as the truck still shut down. I even went as far as to kick it down to STOCK racing mode to see if modified mode did something to shut it down and it still shut down. I also checked the driveline after every run to see if there was any binding or rubbing, everything seemed to be good to go.
Any Ideas?
turn the motor cut off to off and leave the esc one at 220 that should solve the shut down issues. even though the out side can temp was 150-160 the inside can temp could have been 190-200
smokinu is offline
Old 05-19-2011 | 12:43 PM
  #1577
mcheroke's Avatar
I was thinking about doing that but the motor shouldn't be getting THAT hot in 4 minutes shouldn't it?
mcheroke is offline
Old 05-19-2011 | 01:38 PM
  #1578
smokinu's Avatar
seems to be you are a bit over geared for the tekin 4.5 anyways i know they are a super smooth motor and they could benifit from a lower tooth pinion
optimal temp is reached in just a few mins but once there if gearing is right temp should not change.
smokinu is offline
Old 05-20-2011 | 06:10 AM
  #1579
ohiostatechamp's Avatar
I would bump the temp cut-off to 220-230*. The ESC is reading an internal temp and your gauge is reading an external temp. That alone will give you the difference in temp.
Reuben
ohiostatechamp is offline
Old 05-20-2011 | 09:29 AM
  #1580
mcheroke's Avatar
Ive been in contact with Weylin at viper and he gave me some really good pointers on setup with the 10R on 550's. He seemed to think I was getting the motor to go into thermal protection.
- Change the temp cutoff to 230* on both motor and esc
- Keep it on STOCK mode not RACE mode, builds up too much heat
- Increase the Drive PWM frequency to 8000hz with the progauge. Should keep the motor running cooler.
He wasn't sure if the tekin sc4x's have a temp sensor or if the viper is picking up the tekin temp sensor but I have to mess around with it again hopefully tonite.
Still wondering about the gearing though? at 67/12 (associated's recommended gearing) is it still not geared right? If i'm dropping teeth on the pinion isn't that just going to create more heat thru additional rpm's?
Anyone else running a similar setup in a sc104x4?
mcheroke is offline
Old 05-20-2011 | 10:03 AM
  #1581
Randy_Pike's Avatar
Team Tekin
No temp sensor in the Sc4x. And you're a touch undergeared for a typical indoor track. Try a 13T.
Randy_Pike is offline
Old 05-20-2011 | 10:19 AM
  #1582
mcheroke's Avatar
Thanks Randy, I'll give that a try. Motor has a ton of power, very impressed.
I'm in the process of getting a range of pinions its just been taking forever. My LHS decided not to stock the associated ones when they received their sc104x4's and they ended up screwing up 2 of my special orders (they ordered me a tekin 6.5 550 instead of a 4.5, and my order for pinions never got placed). I had to hijack a novak 12t from a buddy just to get my truck running till I received my pinions.
mcheroke is offline
Old 05-20-2011 | 10:22 AM
  #1583
Finally got my Viper esc/motor combo ordered
What would be a good starting point for gearing and ESC settings for a vtx10 and 8.5 motor in a 2wd SC10 running at a VERY tight, technical indoor track? I also run on a medium sized outdoor track, seems like bumping up a tooth or two on the pinion between the two works ok.
needknees is offline
Old 05-20-2011 | 11:00 AM
  #1584
BOLISARIO's Avatar
Originally Posted by BOLISARIO
Ok, I'm not having the best of luck with my VTX R. I was planning to use the esc for the first time today at the track, so I wired,soldered everything up, calibrated and used the pro gauge to make some fine adjustments. Everything worked fine. While on a car stand, I tested forward,brake ,etc to make sure everything is working, then after about 5-10 sec the whole esc just shut down.
I tried different batteries, still not working. I hooked up my old MMP to my receiver and that works perfectly. So I ruled out batteries, receiver, and radio. I even soldered new battery plugs and still the switch won't turn on.
Do I have a bad switch or did the esc just take a dump on me?
I guess no track day for me.
OK, I got my 10R replacement in and hooked everything up...............guess what happened again..........Yup another esc failure!!! I throttled it maybe 5 feet on my kitchen floor, hit the brakes, then reverse and all of a sudden everything shut down on me just like the first esc.
Weylin thinks the first one was some component failure, but twice in a row? I really want to give this esc a shot, I like all the features it provides: the small footprint, powers 550 motors, and I really like tuning the esc without a laptop. But I can't even get this esc on the track without it failing on me. I made sure all my solder joints are clean and solid, made sure none of the joints contact each other,etc. I've owned an RS Pro, MMP, RX8, etc, all my 1/10 esc's have been solid reliable(except for my 1/8 RX8) so I was hoping the VTX10R would be just as reliable. Maybe bad luck hit me twice and hopefully the third time's a charm?
BOLISARIO is offline
Old 05-20-2011 | 11:33 AM
  #1585
smokinu's Avatar
remove reverse.
what motor are you running it with?
smokinu is offline
Old 05-20-2011 | 11:37 AM
  #1586
BOLISARIO's Avatar
remove reverse.
I can't remove reverse, it will not turn on again, just like the first esc.
Tekin 4.5 550.
Old 05-20-2011 | 12:14 PM
  #1587
mini-dub's Avatar
If the motor doesn't have a built in temp sensor then the motor temp cutoff should just be disabled as to not confuse the esc. That will solve your problem.
Start around a 18/84-87, should be good for a tight layout. 20-22/87 for larger outdoor tracks.
I already emailed you back regarding this but if we're posting on here I'll say it again. I'm very surprised you experienced another issue with your replacement 10R as every single VTX10R that shipped out this week was personally tested by myself. I connected each ESC to a radio, calibrated it, and checked for proper motor operation, as well as proper sensor port and Vport fit. This final inspection was performed after two full function tests are performed before leaving the factory. The probability of that controller immediately failing due to component failure for your second time after being full function tested three times before reaching your door is so slim I couldn't find an engineer to calculate the probability. Nonetheless, please send it back again for replacement. I truly hope third time is the charm
mini-dub is offline
Old 05-20-2011 | 01:53 PM
  #1588
I find this very puzzling as well.
I'm curious to see his set up vehicle,component placement, wire routing, soldering, type of radio and servo etc. ( not saying you don't know what you're doing at all). You know what they say about pictures..
Jamie James is offline
Old 05-20-2011 | 04:21 PM
  #1589
savageboy69's Avatar
If someone can help.me it would be great lol, I'm at the track just got my vtxr and 8.5 in my scr. My old combo ran a 78/19 tried that with the vtx it got hot tried a 78/17 got hotter I'm guessing I need a bigger pinion but how big? Don't wanna blow this up
savageboy69 is offline
Old 05-20-2011 | 05:02 PM
  #1590
nikos2002's Avatar
I run 86 with 21-23 with my 8.5/VTX10 combo in my SX10 SC (same ratio as your SCR).
Check your timing also - really don't need to run any higher than 30* on the can - and sometimes less.
nikos2002 is offline
