Like Tree4Likes
Viper RC -
Old 05-05-2011 | 07:59 PM
  #1426
I got my ESC and 13.5 motor today. Thought I would post an install since nobody has.
Here they are in the box:
Unboxed
How not to pre-solder. I put way too much on, made it hard to head it up enough to get the wires on. Just lightly tin them.
The wires are on. I put heatshrink over the motor wires to keep them insulated from the power wires. If I had another colour of heat shrink I would have used it!
Test fitting it
Wires trimmed and everything together. I think I will shorten two of the motor wires to make it look nicer.
Craig
CraigV is offline
Old 05-05-2011 | 08:11 PM
  #1427
DBL15's Avatar
install looks good , i hope to be doing mine this afternoon as well
any trouble at all with doing the programming ?
DBL15 is offline
Old 05-05-2011 | 08:18 PM
  #1428
The only problem I had was not reading the instructions. After I did that it worked perfectly. Before I read them I couldn't get it to link up. The ESC needs to be put into programming mode, then the ProGauge is attached.
It's amazing what one can accomplish after reading the instructions.
CraigV is offline
Old 05-05-2011 | 08:31 PM
  #1429
DBL15's Avatar
just to confirm , thats plugging the esc wires that normal go into your reciever is the part you plug into the pro gauge ?
bit of a noob on these programing things and have all ways paid some one to set them up
DBL15 is offline
Old 05-05-2011 | 09:20 PM
  #1430
Dlewis4's Avatar
R/C Tech Elite Member
No. You take the cord that plugs into the switch and plug in to the progauge
Dlewis4 is offline
Old 05-05-2011 | 09:52 PM
  #1431
DBL15's Avatar
oh ok into the switch thanks for the tips
might be a long night
will set it all up 1st and mounted before trying to program it , might be the safe way
DBL15 is offline
Old 05-06-2011 | 04:30 AM
  #1432
DBL15's Avatar
ok all good and done
just running on profile 8 for now until i work out how to use it right
any know what kv a 7.5T =
so i can start to set my profiles
DBL15 is offline
Old 05-06-2011 | 06:13 AM
  #1433
What is the make and modle of your 7.5T?
CraigV is offline
Old 05-06-2011 | 06:55 AM
  #1434
jdogger1's Avatar
Cool Paul Sinclair Joins Viper RC
Check out the story at www.rcinsider.com.
jdogger1 is offline
Old 05-06-2011 | 10:10 AM
  #1435
mini-dub's Avatar
Originally Posted by savageboy69
lol true but im trying to avoid smoke all together, smoke = bad, you gonna make it to the hank in spokane?
Looks like the Hank is a go!
mini-dub is offline
Old 05-06-2011 | 10:12 AM
  #1436
savageboy69's Avatar
Nice!!!! That makes at least 2 viper powered short courses
savageboy69 is offline
Old 05-06-2011 | 10:16 AM
  #1437
mini-dub's Avatar
Assuming you picked up a VST 7.5 to go with your esc, with stock rotor and 30* timing our 7.5 is 4400kv.
Edit: This table is helpful to have on hand when tuning our boost function
mini-dub is offline
Old 05-06-2011 | 12:49 PM
  #1438
Here you go, something you can save and print out.
File Type: pdf
CraigV is offline
Old 05-06-2011 | 12:57 PM
  #1439
Got the first grouping of Viper products into my 22 for this weekends JBRL...very exciting. The esc and motor and so clean and went it easily. Anyone else notice how light the motor is in comparison to others...oh yeah!
hacker07 is offline
Old 05-06-2011 | 01:25 PM
  #1440
Fodarr's Avatar
Thumbs up
Thank you Weylin for the office tour and all the good info! You guys really have some quality gear! I really appreciate your time. I know your a busy guy!
Talk you soon soon!
Jim
Fodarr is offline
