Like Tree4Likes
Viper RC -
Old 05-06-2011 | 02:36 PM
  #1441
DBL15's Avatar
Originally Posted by mini-dub
Assuming you picked up a VST 7.5 to go with your esc, with stock rotor and 30* timing our 7.5 is 4400kv.
Edit: This table is helpful to have on hand when tuning our boost function
thanks guys for the help yes it is a complete Viper combo and i must say even just starting on the programs you have installed from factory i am loving this combo
as i said i am on mode 8 which is practise as i like to have reverse for our tracks but will play with the pro gauge a little bit and see how i go
i will be buying more of these combos for other cars cheers
DBL15 is offline
Old 05-06-2011 | 03:15 PM
  #1442
Dlewis4's Avatar
R/C Tech Elite Member
Look me up when you are ready for more
Dlewis4 is offline
Old 05-06-2011 | 10:48 PM
  #1443
DBL15's Avatar
will do thanks mate
i will be waiting for the realease of the 550 size as well once i get my Losi 4x4 in the next month , i believe the 550's will be out by then
i am pretty sure the 540 7.5T will be ok in my hyper 4x4 until the losi is back in stock
going to run with a 14t pinon and watch the temps as our indoor track is not big so i hope i will be fine as no shops over here stock the mod 1 pinons
DBL15 is offline
Old 05-07-2011 | 02:34 PM
  #1444
What exactly is slew rate and how does that affect bottom end and top end timing? I love this system!! Finally got a chance to play with some settings outside today.
msave is offline
Old 05-07-2011 | 03:35 PM
  #1445
beazer30801's Avatar
I need some more help got everything hooked up and all I get when I turn on the speedo is a red light and the green N light blinking with a tone and nothing else whats going on I'm not having any luck with these speedo's but I really want to give it a real shot.
beazer30801 is offline
Old 05-07-2011 | 04:13 PM
  #1446
Did you calibrate your transmitter yet? If you have synced your transmitter, then you need to push power button again after you see red and green. Push button and all LEDs will be red, that is programming mode. Only then can you use the progauge. Make sure you hit ok for link device on progauge then you can change settings.
msave is offline
Old 05-07-2011 | 07:24 PM
  #1447
sc10rr's Avatar
Im kind of confused on the gearing in a sc10. i have a novak gtb with the 8.5 viper motor and run 20/87. on most of the setup sheet from ae the team drivers are running 87 spur gears but most of what i read us regular racers are running a 84 spur gear. on comeseethis gearing chart it shows that 20/84 would be a good starting point with a 8.5 motor. so after reading way too much and confusing myself, im looking for a little guidance on what works good and keeps temps down.
sc10rr is offline
Old 05-07-2011 | 07:38 PM
  #1448
I shopping for an ESC for my Hyper TT on 14.8volts
I came accross this unit... Can it drive my 550 novak with 2250kv on 14.8volts no problem?
or should I stick with another Rx8?
pirape is offline
Old 05-07-2011 | 10:46 PM
  #1449
The VTX10R can as I believe you are referring to the 6.5 or 7.5 novak 550. It should be able to handle that no problem.
hacker07 is offline
Old 05-07-2011 | 11:16 PM
  #1450
scootinround's Avatar
The VTX10R can run up to 17V/ 2S-4S Li-Po and is recommended up to 550/No Motor Limit. But for a Hyper I personally can't see anything bigger than a 4.5T or it would be undrivable IMO.
The VTX10 can run up to 17V/ 2S-4S Li-Po and is recommended up to a 540/6.5T Motor
Hope this helps and the Viper set-up will definetly make that Hyper Fly!!!!!
But for the big bot motors for 4X4 you should go with the VTX10R!
scootinround is offline
Old 05-08-2011 | 05:13 AM
  #1451
No my hyper on 14.8v does not go faster than my buddies racing 7.4v with a 4.5t 550 motor...
Its just much more efficient
VTX10R will handle a 550 9.5t can? is it sensored also?
pirape is offline
Old 05-08-2011 | 12:13 PM
  #1452
smokinu's Avatar
yup the 10r is the esc you are after! it will go right in with no problems!
smokinu is offline
Old 05-08-2011 | 12:31 PM
  #1453
jurquhart's Avatar
Is there a viper motor that can be put into the Losi SCTE 4x4? If not is there one that will be coming out anytime in the near future.
jurquhart is offline
Old 05-08-2011 | 12:52 PM
  #1454
if your looking for a 550,they should be announcing them very soon
rtkota360 is offline
Old 05-08-2011 | 01:28 PM
  #1455
smokinu's Avatar
yup
Our 550 cans are moving to production not even team members have them unless you are the special few! who i envy LOL!
But they should be out by the end of the month or so last i heard from Weylin.
smokinu is offline
