Viper RC -
#1456
Im kind of confused on the gearing in a sc10. i have a novak gtb with the 8.5 viper motor and run 20/87. on most of the setup sheet from ae the team drivers are running 87 spur gears but most of what i read us regular racers are running a 84 spur gear. on comeseethis gearing chart it shows that 20/84 would be a good starting point with a 8.5 motor. so after reading way too much and confusing myself, im looking for a little guidance on what works good and keeps temps down.
#1457
Btw all. I have one more VTX10R in stock.... come get it!
Premierehobbies.com!
#1459
If you perform the calibration process and still get the N light blinking when you turn it on, try turning your throttle end points all the way up to their max value and repeating the process, I've had this solve the problem before.
If the problem STILL persists then your radio may have a problem, most likely the throttle pot is worn out and not giving a precise neutral signal. The VTX10/10R esc's are rather picky about this. Try moving your trigger forward and back about 1mm and it will likely see a happy neutral signal and initialize. Changing the deadband to middle or wide also makes the esc more forgiving on neutral signals.
#1462
turn on radio
hold down esc power button (with motor hooked up)
Will hear two tones.
Hold full throttle
two more tones
Go full break
Esc goes lights out
Return to nutral
Esc will flicker give power up tones and go led green for nutral.
Just making sure thats what you are following
#1464
beazer, make sure your throttle trims are centered at zero (even the subtrim).
Also try changing the reverse setting on the channel. The ESC doesn't care, but it might make the neutral more noticeable to the ESC. I did that once to help fix this type of issue.
#1468
Sweet, at least I won't be the only one with a viper in my sc10 4x4. I've had my viper for a week. Now I will get my sc10 4x4 today. I'm really happy with the quality of my vtc10r, well packaged. I'll have the pleasure of tuning the sc10 and viper on Saturday.
#1469
Got any setups for a vtx10R with a 4.5 550 motor? These 4.5 550's run better and cooler without any timing? I'm going to the track tomorrow to try the new esc out for the first time and compare it to the MMP I had on my truck previously. With the MMP, I was geared 12/54(DESC410R) with no timing and I'm temping in the 170's and 105 esc at lipo cutoff which over 10 min. Indoor, small, technical clay track with good traction.
4Likes
