STS engines
#2476
Hi Guys,
I am new to the STS motors, have been running the Mugen X12 for a while now.
I would like to try the STS D3R or the D12X Factory team but I can't seem to find what exactly is the difference between the two engine, maybe you can help?
Also which type of glow plugs are you guys running, OS, Novarossi or Mega?
Thanks for your help.
#2478
yap just want to know sts d5r compare to d12x which one better,no long time no use sts engine,already try nova max,os tz,os speed,palmaris pr12,wasp,so thinking buy sts engine again,can anyone compare this engine thank bro
#2479
The D12X is the higher model , normally about $50 dollars more. Its what STS calls "TEAM Edition". Its got a lightweight piston , filled crank and other features which give it more power.
The D12X also comes in an outlaw version which if you can run it , should be even faster.
The engines mentioned. The TZ and OS Speed. I know these motors and they are very fast. With any given motor it seems if it is just 1-2 years old its already being beaten by faster competition.
Given the D12X & D3R/D5R are more than 1-2 years old its hard to say if it will compete. The always good thing is the STS motor cost less than most motors.
All STS motors like hot glow plugs. These motors take Turbo Hot Plugs. I really like the lrp or ae/lrp #6 plug. These motors are shimmed for 30% nitro stock. If you run 30% and your on a big track. Try the #7 plugs.
I also suggest the RB plugs. Those are very nice plugs as well. I dont notice any leaking either when using these plugs.
#2480
Well I broke in my .21B tonight and I must say I am nothing short of extreamly impressed atm. It has crazy power for the pricetag and appears as if its going to be a very very solid choice in my 8ight. One complaint is the pinch, getting this baby started was a real job, if that counts as a complaint
#2482
Originally Posted by charlesd
I know what you mean. On my d3r it took about 4 full race days + initial break in to get the engine to turn over easily. If I read and undertstand correctly, my engine is at the point where it will start to really perform.
The bigger motors seem to be easier to turn over as well some are just easier to turn over than others , while some are very tight from the factory. I had one that was so tight I had to remove the piston and polished it some to reduce its tightness. Otherwise I couldnt even start it.
The good thing is , come a gallon or two it keeps getting faster as it loosens up and compression should stay for awhile. Weve got some reports of quite a few gallons through a motor and still going.
#2485
Hey everyone,
I was looking for a engine to run offroad in my RC10GT and it looks to me as if these engines are very impressive for the price tag. I am looking at the STS engines because I am on a budget and need something that is fast. I would like an engine that is comparable to the OS .12 CV-R. There are several different engines that STS has put out, can someone give me an idea what engine would be good to use for a pretty open offroad track. Thanks for your help in advance.
Brandon
Brandon
#2486
Originally Posted by oceanhighz
Hey everyone,
Brandon
Brandon
Theres other standard shaft motors , but there really kinda hard to say on power. There pretty scarce on info it seems compared to the D3R's. At least you dont really see anyone running them.
#2488
yea, I know I can get the a SG shaft to work in my car, just figured someone here would know better than I
