Old 06-05-2008, 08:31 PM   #2626
jameslow's Avatar
Originally Posted by 20 SMOKE View Post
I've ran an os but always went back to a nova
Yape...go with novarossi plug... is gd and lasting!
Waiting!
jameslow is offline   Reply With Quote
Old 06-05-2008, 10:29 PM   #2627
wheelhead's Avatar
Send a message via AIM to wheelhead Send a message via Yahoo to wheelhead
Ok it to bad my lhs is to dam cheap to get anything other than os and mcoy plugs. Will have to get some of the online shop. Gotta love amain.
CRT.5
STS .12RS 3port
Ofna High Down Force Wing/Yellow
12mm Rear Shocks/Drilled
http://grandwoodsrc.com/
wheelhead is offline   Reply With Quote
Old 06-06-2008, 02:35 PM   #2628
rregl0612's Avatar
Trader Rating: 33 (100%+)
sts 21 mkII for sale here cheap.!!! http://www.rctech.net/forum/showthre...26#post4508026
Thanks to my sponsors, My Wallet, endorsed by Some crazy pharmaceutical corporation!!!
Member of "The White Wheel Mafia!"
Bumps and Jumps, Pitstop Hobbies, LCRC!
rregl0612 is offline   Reply With Quote
Old 06-08-2008, 07:13 PM   #2629
spy
spy's Avatar
Default .
hey CharlesSD . i run the new sts S12X3 engine last race (at RCPiKERIVER.COM) ENGINE was fast,reliable... was running bit too hot...
btw. TQ`ed and win...with a new fastest lap
Steve Laliberte
______________________________
* RCAmerica*XRAY*HUDY*Gravity*TeamEAmotorsports*SMC*SLYgraphix*
spy is offline   Reply With Quote
Old 06-09-2008, 06:55 PM   #2630
charlesd's Avatar
Hi Spy,
I thought you were running a JP. Goes to show that the STS is plenty fast. I just hope it's reliable and solid conrod wise as it seems to be sts's weak point.
I'll check it out next race. ( have to fix my front diff - after the few back flips i did
charlesd is offline   Reply With Quote
Old 06-14-2008, 06:56 PM   #2631
crazy4wdracer's Avatar
Trader Rating: 25 (100%+)
Send a message via AIM to crazy4wdracer
I just bought a used STS D28M off a guy, and it only has a quart of fuel through it. He had it in his HPI Savage and he used a roto start backplate. I am putting this engine in my truggy which I have set up for bump start. I see that STS sells a bump start engine but I can't find a bump start backplate to put on my engine. Does anyone know where to buy one or have a part number for the backplate?
crazy4wdracer is offline   Reply With Quote
Old 06-16-2008, 05:58 PM   #2632
freestyles's Avatar
Trader Rating: 14 (100%+)
Arrow i love STS!!
Hey there guys, I have been running a sts d12e for about a year now and it's been great. Only issue i have had with it is the o-rings behind the mid range needle leaked after a while. Nothing a $5 bag of o-rings didn't fix. So when i bought a buggy i had to get the sts d30m. It goes great but it just sounds like a motor bike. I am pretty sure the bearings are ok so i have no idea what it could be. Has anyone had similar problems? The temp, smoke, fuel ecconomy are all good it just sounds very loud.
freestyles is offline   Reply With Quote
Old 06-16-2008, 06:34 PM   #2633
wingracer's Avatar
Trader Rating: 24 (100%+)
Loud usually means either a loud pipe or an exhaust leak.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 06-20-2008, 07:35 AM   #2634
freestyles's Avatar
Arrow TORQUE PIPE
The pipe i am using is the VXR FIRE-T. The "T" stands for torque so maybe i might change pipes and see how it goes.
Old 06-21-2008, 02:47 PM   #2635
Smile
i have a ? i have the new sts d28 pro 5 port truggie motor #2809. when i took apart to clean cause it is new heard of q\c but it was very clean no problem there. any way when i took off back plate and carb it had an all black crankshaft . at the sts website it shows a polished crankshaft only the threads were black for fkywheel nut. does anyone know if thier crank is all black or polished on sts d28 pro 5 port truggie motor #2809. any help would be sweet. thax
james1212 is offline   Reply With Quote
Old 06-22-2008, 09:52 PM   #2636
anyone here
Old 06-22-2008, 10:02 PM   #2637
jameslow's Avatar
Originally Posted by james1212 View Post
anyone here
hi... from what i know black coated crank shaft are better as in it reduce friction n protect the crank! As for if it is right shaft for that engine i have no idea cause im using the .12 engine. Just my 2 cent!
Old 06-23-2008, 04:52 AM   #2638
speedy2's Avatar
hi I run .21 engines
if this crank was in it, they just changed to putting these in
that's all, I think..
in general, black cranks are more hardened and more resistant
but opposite, they could eventualy break easier
//JQ The Car forever/ Soar //Protek-Ace-JR
speedy2 is offline   Reply With Quote
Old 06-23-2008, 04:08 PM   #2639
thanx for your 2 cents. iam going to break it in later today or tomaro. is byrons 20 nitro 16 oil ok to break in motor with the stock 1aluminum and 1copper shims. my brother has the hyper 21 8 port race 2.7 hp at 38000 is this fuel good for him for breakin also he has same shim setup.and whats better sts d28 pro 5 port truggie or the hyper 21 8 port race black block. we have a little bet going.
Old 06-23-2008, 04:42 PM   #2640
my brothers hyper 21 8 port race with black ceankcase has a boost tube from under carb on crankcase to the backplate can i do this to my sts d28 pro 5 port triggie motor . dose it even help what dose it do .
.:Go Engines vs. Jammin Engines:. lanerbrainer205 Nitro Off-Road 20 12-23-2007 04:46 PM
.12 Engines sale all new pipes too. 6 engines ericsp2 R/C Items: For Sale/Trade 1 08-06-2007 02:19 PM
os engines compared to rb engines rhymster Onroad Nitro Engine Zone 4 08-03-2007 05:13 PM
IDM engines and picco engines foampervert Onroad Nitro Engine Zone 5 11-23-2006 05:36 AM
SH engines crazyjr Onroad Nitro Engine Zone 7 01-20-2006 03:13 PM
