Old 04-29-2007, 07:57 PM   #2491
Trader Rating: 49 (100%+)
thanks smoke
oceanhighz is offline   Reply With Quote
Old 04-29-2007, 08:26 PM   #2492
drfritz's Avatar
Originally Posted by oceanhighz
thanks smoke
Said to report that my 3dr has finally seen its last race day.it put me second on the grid for the main and had the lead till drive mistake and quick car repair in the pits, ened up fouth for the day but had power problems at the end and sucked a plug right at the end of the race, installed new plug and sucked it right of the bat. did a tear down and found wrist pin bushing gone, got really lucky that I did not break the rod..... not bad for over 6 gallons of fuel all at race condition and no i never changed the rod. got another sts on the way,i'll rebuild the old sts for a back up.....
drfritz is offline   Reply With Quote
Old 04-30-2007, 02:49 PM   #2493
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Artificial - I,
Can you talk a little about the new STS .21 Offroad engine coming to the market, i need that info for a friend in Chile,
thanks,
Patricio "PATO" Concha
E-Mail : [email protected]
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Old 04-30-2007, 02:58 PM   #2494
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
Ive got pictures and small information. Will post them tonight for everyone.
Artificial-I is offline   Reply With Quote
Old 05-02-2007, 03:16 AM   #2495
Trader Rating: 44 (100%+)
does anyone know the diff between the sts 403 and 702 exhaust? i assume based off the descriptions the 403 is a mr or he pipe and the 702 is le or mr pipe
aka mid range/high end, low end/mid range?
T5M 7.5
22 3.0 7.5
SickWitiTRacing(Jayson)
NitroLuver is offline   Reply With Quote
Old 05-05-2007, 06:02 PM   #2496
dido41's Avatar
About this STS D.21T motor. I really like the power. it has low and top end. I bought one mid season last year. I broke it in, then run low speeds for one race day then run it for 2 more weeks at full out. I was in the warm up laps for the main on the 4th week out and the crank broke. I got the parts to replace it but the race season was over by then. So this year I took it out and run 6 tanks thru it and guess what??? Today the new crank broke in the same place as the first one did. What’s up with that?
Have any of you guys ever heard of this happening to this motor before?
dido41 is offline   Reply With Quote
Old 05-06-2007, 02:16 AM   #2497
Maximo's Avatar
did you replace the bearing as well as the crank ?
usualy the rear bearing is what causes the crank to break.. STS uses cheaper bearings and they dont last to long in race conditions...
Maximo is offline   Reply With Quote
Old 05-06-2007, 06:54 AM   #2498
dido41's Avatar
I used the bearings they sent me. in both cases the bearings looked and felt fine.
Old 05-06-2007, 10:16 PM   #2499
jfc_tech's Avatar
Send a message via Yahoo to jfc_tech
my sts21B is still intact even after 3 major races and few bashing sessions. still running good.
whats your method of run-in it?
i think 21T shud be the same case. in fact shud be better becoz it came afterward. my 28M is still running good too.
If you are in front of me, That's because I let you!
jfc_tech is offline   Reply With Quote
Old 05-07-2007, 04:54 AM   #2500
dido41's Avatar
if you mean do i bash it. no.. i just use it to race. and i was doing test and tune when it happen. the first time i was on warm up for the main. i always run a little on the rich side so it does not get hot. right around 220deg. the first was i was useing 20% fuel the second time i was on 30% with .700mm shims. it had all new bearings. new crank, new rod.. the track is about 100x70 lots of short shoots. nothing to even get the motor to full RPM's.
Old 05-07-2007, 01:58 PM   #2501
Send a message via AIM to Kave
what are people getting for runtime with their 21B and the sts pipe? Im trying to decide what pipe I want to order and one major thing i wanna get is runtime.
Kevin
Kave is online now   Reply With Quote
Old 05-07-2007, 09:42 PM   #2502
jfc_tech's Avatar
Kevin
my 21B with HN 053 pipe lasted 7minutes.
Old 05-07-2007, 09:52 PM   #2503
jfc_tech's Avatar
i don't mean u bash it to get such result, but if u did, like me too, it still should be intact. im using 30% race and bashing. the shims are 1 bronze and 1 silver only. I am using Novarossi Turbo long plug. Hot.
either the run-in is not fully done yet, like 10 tanks, no less even using WOT style, or you just got one bad engine. sorry to hear that. hope next one better. Im still using stock. and it can even wheelie my HN CRT on the straight.
Old 05-09-2007, 11:50 PM   #2504
bjc
Got my new D21T Mk11 the other day and here are some photos.
Excuse the poor quality
For your info I wasn't happy with the shavings left all around the 3 rings on the piston, obviously someone forgot to clean it after they were cut!
This engine better be good...
STS engines-114_1475.jpg   STS engines-114_1477.jpg   STS engines-114_1481.jpg   STS engines-114_1483.jpg   STS engines-114_1484.jpg
bjc is offline   Reply With Quote
Old 05-10-2007, 06:29 AM   #2505
Maximo's Avatar
I have been seeing almost all the latest STS engines coming with filings in the piston grooves....
.:Go Engines vs. Jammin Engines:. lanerbrainer205 Nitro Off-Road 20 12-23-2007 04:46 PM
.12 Engines sale all new pipes too. 6 engines ericsp2 R/C Items: For Sale/Trade 1 08-06-2007 02:19 PM
os engines compared to rb engines rhymster Onroad Nitro Engine Zone 4 08-03-2007 05:13 PM
IDM engines and picco engines foampervert Onroad Nitro Engine Zone 5 11-23-2006 05:36 AM
SH engines crazyjr Onroad Nitro Engine Zone 7 01-20-2006 03:13 PM
