Old 06-05-2006, 07:34 AM   #2326
Default Alternate pipe for d21t
I just purchased a d21t and was wondering what othr pipe does well for this engine as there are no sts pipes available right now. thanks.
sho-nuff is offline   Reply With Quote
Old 06-06-2006, 12:20 AM   #2327
underway's Avatar
Trader Rating: 48 (100%+)
JD is that you? If so what you runnin that 21t in?
underway is offline   Reply With Quote
Old 06-06-2006, 02:13 AM   #2328
Sry underway, I'm not jd. But if you're interested the sts 21 is going in a CEN matrix.
Old 06-13-2006, 04:28 AM   #2329
::TEAM SRGS::'s Avatar
STS
SO any new 12 size STS motors comeing soon??
Ross
Nikon D300
Olyumps E20
nikon lens
28mm
185mm
300mm
::TEAM SRGS:: is offline   Reply With Quote
Old 06-13-2006, 05:14 AM   #2330
Moderator
Artificial-I's Avatar
Trader Rating: 17 (100%+)
Send a message via AIM to Artificial-I
I dont believe so at this time.
Artificial-I is offline   Reply With Quote
Old 06-25-2006, 06:46 PM   #2331
Post
Hi
L ran my D3R on the weekend had lots of probs with it l ran it on the banch fine l put it on the track for 3 laps it lost proformans and tune any help would be good
thanks Ross
Nikon D300
Olyumps E20
nikon lens
28mm
185mm
300mm
Old 06-25-2006, 07:39 PM   #2332
hey whats a good 12 for a beginner needs to be pull start and side exhasut does sts offer and engines in that configurisation?
thanks all
Josh P
to make Keith happy
Corally phi
M11
SP GT
SP 5.5,17.5
aus jd 2703 is offline   Reply With Quote
Old 06-26-2006, 07:09 AM   #2333
aus jd 2703: as far as I can see on the website, they do not carry a .12 engine that has a pull start, nor a side exhaust.
Team SRGS: you may try a base line setting as 5 full turns out on low and 2.5 turns out on high then begin to lean out the high end from there at 1/16 of a turn increments or for most people that use clocks (2 clicks....12 clicks equals one full turn). Good luck.
sook is offline   Reply With Quote
Old 06-27-2006, 06:40 PM   #2334
Post
thanks For that
Ross
Nikon D300
Olyumps E20
nikon lens
28mm
185mm
300mm
Old 06-28-2006, 04:59 AM   #2335
arghh's Avatar
anybody ecperience with the new economy series D21E 3 port..
arghh is offline   Reply With Quote
Old 06-28-2006, 05:03 AM   #2336
jfc_tech's Avatar
Send a message via Yahoo to jfc_tech
at last, i found u here
If you are in front of me, That's because I let you!
jfc_tech is offline   Reply With Quote
Old 06-28-2006, 07:17 PM   #2337
arghh's Avatar
headache..which one to choose..D21E 3 port, D21B 5 port or D21T 5 port turbo.. sure the 5 port turbo will blast like hell, but what about the 3 port since this is the latest of the three..
Old 06-28-2006, 07:57 PM   #2338
jfc_tech's Avatar
i dont have the real details or facts, but i think if u not concern with price, go for the Team... jauh bezakan the price?
it has the same spec only with 3 ports(D21E). about fuel economy, probably, but i dont know. i hope someone can help arghh here.
Old 06-28-2006, 07:58 PM   #2339
jfc_tech's Avatar
ok, main difference, one with turbo plug one not. one with green head, one gray black.
Old 06-29-2006, 05:14 AM   #2340
Moderator
There are big differences of the 3. If your going to get the motor , the D21B or D21T is your best choice. E stands for economy or sport edition. Its probably not going to perform as fast as the D21B. The D21T has a modified crank , dished piston , lightweight material for the piston and more.
.:Go Engines vs. Jammin Engines:. lanerbrainer205 Nitro Off-Road 20 12-23-2007 04:46 PM
.12 Engines sale all new pipes too. 6 engines ericsp2 R/C Items: For Sale/Trade 1 08-06-2007 02:19 PM
os engines compared to rb engines rhymster Onroad Nitro Engine Zone 4 08-03-2007 05:13 PM
IDM engines and picco engines foampervert Onroad Nitro Engine Zone 5 11-23-2006 05:36 AM
SH engines crazyjr Onroad Nitro Engine Zone 7 01-20-2006 03:13 PM
