Like Tree352Likes
NOVAROSSI Engine thread....
Old 02-28-2013 | 02:56 PM
  #5071
houston's Avatar
Originally Posted by beidle99
I run the 2096 with the 41021 on my plus 4, very smooth, great top end and run time. Some have reported good results running the 9901/41001 header but I havn't tried that combo yet. What sirio pipe are you using? my plus 4 liked the 2058 but I found the 2096/21 to have the same top end but better run time.
Try em all , find what you like
Robert batlle won worlds with 2096ss/41021 , go figure
houston is offline
Old 02-28-2013 | 04:12 PM
  #5072
beidle99's Avatar
thats why I will probably just stick to the same combo. The 2096/41021 really produces a lot of usable power. No excessive wheel spin, the buggy just squats and goes. It actually made me flat land a couple jumps because I don't loose momentum spinning on short take offs. That combo along with a properly tuned clutch...read Buku, and a good throttle finger lead me to do 10 minute stops and still had fuel in the tank at the end. It is almost electric like.
beidle99 is offline
Old 02-28-2013 | 04:18 PM
  #5073
merdith6's Avatar
Default Westley Pipes
The P5 with the 2096 41001 combo is dirty.
merdith6 is offline
Old 02-28-2013 | 04:23 PM
  #5074
TX_Punisher's Avatar
9886/41001 combo on the way. Hopefully I can turn down the throttle EPA and still have power to spare.
TX_Punisher is offline
Old 02-28-2013 | 06:41 PM
  #5075
jonw's Avatar
jonw is offline
Old 02-28-2013 | 11:39 PM
  #5076
kelv's Avatar
Cool
thanks guys for the feedback. appreciate it.
am using the Sirio 2653 pipe which makes this engine really lively.
will try the 2096/41021 combo first.
anyone know what combi elliot boots is using?
thank again.
kelv
kelv is offline
Old 03-01-2013 | 06:58 AM
  #5077
houston's Avatar
thank again.
kelv
2096ss/41021
houston is offline
Old 03-01-2013 | 04:32 PM
  #5078
Timox's Avatar
I wonder when the new 2096 51020M pipe will be available ? Which is the actual one Batlle used.
Should be a lot lighter than the SS one which is good as the SS ones weigh a tone.
http://www.liverc.com/news/new_produ..._winning_pipe/
Timox is offline
Old 03-02-2013 | 07:32 AM
  #5079
beidle99's Avatar
I wish they would put the reinforced stinger on the SS. Mine got pretty beat up at our last race of the season last year. Pushed the stinger in and took about 5 freezes to get the dent out of the side before the pressure line. I was pretty
beidle99 is offline
Old 03-02-2013 | 07:04 PM
  #5080
Timox's Avatar
The SS ones would be tough to freeze dents out of also i would imagine ? Being thicker in the walls.
Timox is offline
Old 03-02-2013 | 08:04 PM
  #5081
I agree, but until they do you can do it yourself with a 2 part metal/epoxy glue, i've used the plasticine like type mentioned and it works great.
http://www.rctech.net/forum/onroad-n...huast-tip.html
mdchris is offline
Old 03-03-2013 | 02:54 AM
  #5082
Default Manifold
Hi, Will the 41005 header make the most power on the .25 and .28 engines?
latemodel13 is offline
Old 03-03-2013 | 10:48 PM
  #5083
mrbusta's Avatar
Can someone z help the plus 4 t is the white carb restrictor
6 mm thanks
mrbusta is offline
Old 03-04-2013 | 12:18 AM
  #5084
Lille-bror's Avatar
6 mm thanks
Yes it is
http://www.amainhobbies.com/product_...buretor-Insert
Lille-bror is offline
Old 03-04-2013 | 02:35 AM
  #5085
mrbusta's Avatar
Originally Posted by Lille-bror
thanks Lille-bror appreciate that
mrbusta is offline
