Like Tree352Likes
NOVAROSSI Engine thread....
Old 04-06-2014 | 04:57 PM
  #6571
Maximo's Avatar
I should add that I have seen crankpin wear from dirt, shoe polish.... metal polish, chrome polish..lapping compound ( not mine obviously ) ....... Multiple times I have seen crankpins worn down before the engines were ever even fired....I guess guys decided to try using an abrasive compound and a drill to speed up the breakin...Needless to say the results weren't very good !
Maximo is offline
Old 04-06-2014 | 06:29 PM
  #6572
Originally Posted by Maximo
I have never seen crankpin wear issues with Byron's 30/11 !
Just figured i would put that out there for Byrons guys supporting this blend
I take it this means you have with 30/9?
fbrk8r is offline
Old 04-06-2014 | 07:33 PM
  #6573
revo61's Avatar
Has any tried using dirt bike air filter oil? If so, which brand?
revo61 is offline
Old 04-06-2014 | 08:10 PM
  #6574
I use motul and belray... There both Good!!! Just use a rag to clean the excess
segreda is offline
Old 04-07-2014 | 12:21 AM
  #6575
dmartin's Avatar
I've been running Belray for over a decade. Great stuff.
dmartin is offline
Old 04-07-2014 | 01:27 AM
  #6576
Camash's Avatar
Hi all I have a 28-7t and I have run 8 tanks thru 25% for run in,heat gun used to get temps right b4 starting this was a month ago the problem is that I've never been able to get on the throttle it just wants to die I have searched far and wide tried tuning it from a u tube tuning vid tried new turbo plugs still the same it just won't take off like I know it should so I thought I could ask here and see if any one can help me??i hope the motor is ok
Camash is offline
Old 04-07-2014 | 02:05 AM
  #6577
mourinho's Avatar
have you leaned it out a bit yet? they come very rich for break-in.
mourinho is offline
Old 04-07-2014 | 05:03 AM
  #6578
Camash's Avatar
Yeah I've leaned it (hsn) & lsn on the last tank of run in I drove around at 1/3 throttle when I went to give it a little bit more it just died no high rev b4 it just died so I leaned it a bit a bit more a bit more don't want to go too far tho funny thing is when it dies it starts straight back up no worries,man it's got me beat think I should maybe check the piston perhaps
Camash is offline
Old 04-07-2014 | 05:25 AM
  #6579
Maximo's Avatar
still sounds too rich...what fuel % are you using ?
Maximo is offline
Old 04-07-2014 | 10:35 AM
  #6580
Camash's Avatar
I am using 25% A T Racing fuel
Camash is offline
Old 04-07-2014 | 11:37 AM
  #6581
Lille-bror's Avatar
I've been running moonshine brew for the last 6 years now (no broken conrods but two broken cranks (awfull STS and a nice Nosram)... and shortened lifespan on bearings when I ran pure synth oil). I found (thanks Monty and Novarossi) that you need approx. 3% castor in the fuel to get a good lifespan and no premature wear on engines.
I'll start running Byron again. For me, the Race 25/11 is great for practise, for drivers that whats a really long lifespan on their engines or for drivers that runs their engines too lean = too much oil. The Pro 25/9 is great for racing but your engine doesn't last as long as with 25/11. As Neal told me, you don't need to lean your engine as much to get it run clean with low oil percent as you do with higher oil percent fuel.
I'll mix Pro and Race 50/50 to get the best of both fuels
Lille-bror is offline
Old 04-07-2014 | 12:12 PM
  #6582
Race4598's Avatar
Has anybody here had any experience with the new Clio p5? I'm thinking about switching from O.S back to nova and thought I might give it a try
Race4598 is offline
Old 04-07-2014 | 01:14 PM
  #6583
Maximo's Avatar
Default Clio Internals ! sorry guys no bypass ports !
Clio !
Maximo is offline
Old 04-07-2014 | 01:59 PM
  #6584
merdith6's Avatar
Default haha
Clio !
Awesome, Is that one for me? Who needs bypass ports when you have Neal modding them.
merdith6 is offline
Old 04-07-2014 | 02:01 PM
  #6585
I just recently switched from Byrons 30/9 to 30/8 race blend. I've been told the the 30/8 uses a different type of oil and actually lubricates better then 30/9. Can anyone alaborate on this?
rcmoe is offline
