NOVAROSSI Engine thread....
#6586
Hey guys, just wondering how to get decent fuel economy out a P5XL which has been running 25% Neo+ fuel since break in.
Have put through just over 4 litres now and it's turning into a beast, even when rich, but just scraping the 7 min run time required to get through the heats.
I'm running a 41020 manifold with an SS 9901 pipe
Is it worth investigating the different insert sizes or consider leaning LSN and HSN?
#6589
#6590
Houston, you seem to be a big fan of the 41005. I am too and I have one but I recently have moved away from it because it seems to be a more suitable header for hi bite tracks to ME because of its abruptness. My home track is super loose so thats why I no longer use it on this particular track. Whats your thought on this?
#6591
#6592
I haven't really touched the LSN much, would be lucky to turn it much and the HSN is close to flush
The main reason for the 41020/9901 combo is that I'm still learning how to drive in general.
What is the expected run time I should expect out of the engine? 9 - 10 mins?
#6594
#6595
This is on a Losi 2.0 buggy (soon to be 3.0). I did play around with the HSN and turned it about 2 -3 mm and the LSN a fraction also, gained maybe 30 seconds.
But that might not have been a true gain though as I was driving differently in each heat.
Full bore in first 7 min heat, more controlled in the second 7 min heat, and ran a two stop strategy for 20 min final with a little fuel left
#6596
#6598
Alll depends on what pipe you use it on for one but yes it does make an engine get on the pipe quicker for the most part , I use it with 9853ss mostly , funny thing is it smooths tbd 9853ss out but on many of the top end pipes it almost does the opposite . Completely disrupts the scavenging loop in comparison to the 41021
I run it on a 9886 and its exactly the opposite you mention. How is it on a 9901?
#6600
352Likes
