NOVAROSSI Engine thread....
#7337
Guys what would you recommend on a Novarossi P5XLT plug? the place that I raced is tropical weather which is 80-90's & hopefully can make it to the Philippines Big Event next year anyway ... this is gnna be my first time to try the Novarossi Motor which I heard a lot of good things ,I got the motor from the other site which is 3/4 gal. and last thing about the shim? too which I have no idea how many shim do I need ,i will be using the 20% for now ..until the 30% fuel gets here ,please any input /suggestion , thank you..
Hope fully your engine is in great shape
#7338
Quick question. I got a P5 and want to put a LCG head on it. Are the BTT and Keep Off heads the same bolt patterns? Its going to get bead blasted so it doesn't matter what it says. Mainly, I want it to sit lower so its under the roof line on the body.
If anyone has a used one that is still straight, let me know. Don't care about scratches, just straight fins...
#7340
I was wondering the same thing?? I have 2 p5 xlt's with bent fins and would like to know if keep-offs, btt WC edition heads fit and if their are other any other Nova heads that fit, preferably upward finned heads, as well?? Thanks
#7341
Rex
#7343
#7345
#7347
Leave shimming , if you want to change anything ,get some .10mm and replace the .20mm with .10 for .70mm
352Likes
