NOVAROSSI Engine thread....
#8836
#8837
Nova's have the biggest shim stack of all the engines...average being 0.7 mm between piston and button....a stock XZB Sopeed has 0.4 mm between piston and button ( And can run a P3 )
#8838
Very good to know! Engine's got about 4 gallons so it's good to go. I've been looking for more top-end so I just got a 9886 per your recommendation and I'm going to throw a 41019 on it too. Should be a screamer. Thanks for the info Sir.
#8839
that is the main reason why OS Speeds are so fast compared to most others...having the head tight like that makes a massive difference in performance.. An engine can have the best port timing, the fanciest crankshaft, all the bells and whistles and if the head isn't tight enough it will all add up to nothing...Its amazing having a dyno and being able to see how much effect the shims have on power...egnines that are known to be mild can simply be over shimmed and can turn into total beasts just by lowering the button by a shim or two.... conversely add 0.3 mm of shims to a OS Speed and watch what happens to it ! will go from wild to mild instantly......
#8840
also to add here...when you do drop shims you must be careful not to run it too lean...use the glowplug as your canary in the mine and if you see any distortion in the coils its not happy..either fatten it up, run a cooler plug or add a 0.1 mm back to it....They can run really good this way but have less tolerance for being lean, thats when they will start to detonate....
#8841
New engine- Drake special edition 5 port
http://novarossidirect.com/ADAM-DRAK...FF_p_3411.html
Looks kinda cool, not sure what it's all about though. There's not much else out there on it, except I'd guess it's mostly based off the Rex R21 Plus5
#8842
#8843
#8844
What do you think about the 9886/41019 combo on a Cinco BT in a buggy? Hopefully I'm not going to lose too much bottom.
#8845
#8846
it will will probably have better bottom then all the 3 chamber pipes like the 2096 and 9901
#8849
352Likes
