NOVAROSSI Engine thread....
#8986
#8988
if you are experienced with how to tune, the idle gap sort of just comes naturally. If you are a beginner, measuring it can be a helpful tool with respect to obtaining a setting close to correct, as most beginners at anything are not in fact experts from day 1. Hope this explains the phenomenon.
#8989
#8990
#8991
The insert doesn't block the carb bore in any way that makes it possible to tune it that way, the air will pass right by.
#8993
http://www.planethobby.com/products/...vloaAn2I8P8HAQ
Found a good deal on these just thought I'd share for anyone looking to stock up on glow plugs... cheapest I've found so far. Shipping is like 4 bucks for usps first class.
#8994
Question: I have a Plus4BTT with a few gallons on it and was broke in well. Heat soaked and tuned if the engine dies it's hard as hell to start. It will not start until it sits for 5min or so. Heat soaked it's running about 220F or so in 90F weather. New plug and doing the same thing. Seems to have good pinch still when heat soaked. Running 20% Byrons. Please help.
#8995
#8996
For those that are running the Elite 5...
Which pipe/mani combo do you feel provides the most overall power? Or best top end?
I'm considering either a stock Elite 5 or the TNS modified.
I previously ran the OS XZB Spec II and want to be sure I can get similar rip/power out of this Nova Elite.
Thx guys!
Thx guys!
#8997
Thx guys!
Thx guys!
As far as Nova pipes 9886 with either 41032 or 41001 will make some stupid power especially with a modded engine.
If you stick with a stock mill and really want it to scream pop one of the shims out after it's broken in. Even dropping the shimstack down from .8mm to .7mm makes a huge difference with a good 30% race fuel
#9000
Thx guys!
Thx guys!
352Likes
