Like Tree352Likes
NOVAROSSI Engine thread....
Old 04-04-2014 | 10:42 AM
  #6541
merdith6's Avatar
Default hehe
Originally Posted by Maximo
well I think rods splitting up the middle are more related to the fuel being used and how the engine was tuned and run then anything else... When a rod splits it means the rod bushing has spun inside the rod,which means there was enough heat and friction between the rod bushing and the crankpin to break the bushing loose inside the rod, which is no small feat.... To me this is more of a lubrication issue then it is a bad rod issue...run a engine hot and lean at 40 000 RPM using cheap fuels with low oil and this is the types of issues your going to see...... As you can imagine I work on many engines and more and more I am seeing a larger number of engines with badly worn crankpins..Engines that only have 3 gallons of fuel thru them are already showing 0.002" or worse out of round...With very distinct heat and friction markings from the bushing....
I wont argue that some rods are not stronger then others, as the new 14 rods are definitely stronger then the 13 rods.........But when i see a split rod its a clear indication of a spun bushing, and spinning a bushing means there was a substantial amount of heat and friction present so I would blame the fuel and the tune much sooner then I would blame a faulty rod......
Cars are becoming faster and faster, engines are being spun harder and faster then ever before, and because of this we will start seeing more and more fuel related wear issues....
Perfect explanation.
merdith6 is offline
Old 04-04-2014 | 11:53 AM
  #6542
PERROTTO's Avatar
I think the rod develops a small crack between the oil hole and bushing which would absolutely cause the bushing to spin. As you said Neal, spinning that bushing is no small feat.
I would say misuse and abuse play a very large role in causing this small crack to develop: flat landing, getting piston stuck in TDC, not preheating tight engines, flat landing, and flat landing.
PERROTTO is offline
Old 04-04-2014 | 02:43 PM
  #6543
houston's Avatar
i know exactly what does what and why , i wish i could freely speak my mind but i will not
the rod in the roma is a completely different rod than the .21 engines have , it is from the .28 engines
i have not seen one 14 rod fail as of yet
i will say backflips, flat landers , lawn darts and the like are NOT good for engine internals !!!!!!
neither is cold running
i will agree some of the fuels are CRAP out there today , its a very hard balance to obtain with fuel oil pkgs as these engines are quite unique in the sense that they receive their lubrication from the same source of liquid that produces the combustion and not having a lubrication cavity for moving parts to bathe in
i will not go into detail of what i think of which fuels but like Neil i see many many engines on my bench and inquire about the life of the engine and fuels that have been ran , etc. etc.
houston is offline
Old 04-04-2014 | 04:17 PM
  #6544
beidle99's Avatar
I think you forgot to mention flat landing is bad...
beidle99 is offline
Old 04-04-2014 | 07:37 PM
  #6545
Question on this rod splitting, You mean to tell me that these guys I know that have had these failures with there Nova rods. Had it happen because of there fuel? The way they broke the motor in? Or because of flat landings, lawndarts, etc? When these same guys I know have been racing for years with other brand motors and never had a issue even similar? Your telling me Byrons fuel is crap? Which btw is the #1 selling fuel in the world. Your telling me there is no problem with the rods? They are splitting perfectly. I couldn't cut them in half that perfect if I tried. I actually considered buying 2 for me and my son. Then I thought of all the guys I know from different tracks that have had this problem. So I decided to buy another brand THANK GOD!
purple rides is offline
Old 04-04-2014 | 09:07 PM
  #6546
trax70 guy's Avatar
Yeh What he said
I will stick with my Nova,s But If the rods stamped 13 it,s going in the TRASH where it belongs Will get some 14,s
trax70 guy is offline
Old 04-05-2014 | 04:07 AM
  #6547
Thanks for the responses guys. The engine was broken in very easy with about 12 tanks just like I do all my enignes. The temps never have been high on this engine. Maybe 250-260 max. The flat landing I had at PNB were epic, but not different than the ones I had in the buggy with an 8+ gallon P5. Who knows, that could still be it.
Here's a pic of the rod before I tore it down:
fbrk8r is offline
Old 04-05-2014 | 04:38 AM
  #6548
beidle99's Avatar
Originally Posted by trax70 guy
John,
unless your buying old stock the 13's are long gone.
beidle99 is offline
Old 04-05-2014 | 05:04 AM
  #6549
Maximo's Avatar
what fuel were you using ?
edit... did you happen to measure your crank pin ?
Maximo is offline
Old 04-05-2014 | 07:18 AM
  #6550
Forgot to mention I ran about 3/4 gallon of vp 30% and switched to Byron's pro driver 30/9 for about 5-6 tanks.
fbrk8r is offline
Old 04-05-2014 | 07:19 AM
  #6551
Crank is 5.33nm
fbrk8r is offline
Old 04-05-2014 | 07:21 AM
  #6552
Maximo's Avatar
Crank is 5.33nm
is it concentric left to right and top to bottom ? basically does it measure itself as round ?
Maximo is offline
Old 04-05-2014 | 09:38 AM
  #6553
houston's Avatar
Crank is 5.33nm
Cranks no good
They start off at 5.48-49
Its not the fuel Neal
houston is offline
Old 04-06-2014 | 05:16 AM
  #6554
merdith6's Avatar
Default Clio
I found the exploded view of the Clio It does look like it has bypass ports.
http://www.mugenseiki.com/images/nov...ew/CLIO-P5.pdf
I bet this thing has a few more rpm's than the p5.
merdith6 is offline
Old 04-06-2014 | 06:39 AM
  #6555
Originally Posted by houston
Cranks no good
What in the world would have caused that with such a new engine?
fbrk8r is offline
