NOVAROSSI Engine thread....
#6721
Factory Hard Coat Pipe...
After market black looked great when new...
But unfortunately once the black coated pipes were a gallon or so used, the black turned to bronze...
#6722
Looking for some opinions.... for the keep-off -4, what restrictor has been successful that is a good compromise between power and fuel economy?
I ran the 5.4mm restrictor but it seemed to affect the power too much... so much so that I had a hard time making a double on a track. The next day, on another track, I switched to 6.5 and it was noticeably better from the power perspective, and seemed to be able to pull off 10 minutes if I was cutting it close. I was just curious what others have been using as a balance. I was going to try the 6 to see if it was any better.
Thanks.
Thanks.
#6723
Thanks.
Thanks.
I started using other methods to get runtime without having to go to a smaller venturi such as making sure you are very close to the legal fuel limit of 125CC, I use an exhaust cooler (not sure if I've noticed a huge difference on this one, but it seems to give me an extra 20-30 seconds), and the big one is throttle control, a good tune, and the right pipe/header combo. If I'm limiting wheel spin and I have a good crisp (but not too lean) engine, then 10 minutes with a 6.5 can be done fairly easily on most tracks.
#6725
about to get a p5 for my buggy and wanted opinions on a few things.
1)for pipe would the 2096 or the 9901 be the better pipe with the 41021 header for a more smooth power band, im still a newer driver so I don't need the ridiculous top end just yet.
2) for break in what venturi should i use- the one I plan on running or is there a better recommendation (ie. no venturi or smallest venturi), I plan on using the heat cycle method.
3)and what is a good venturi to start with
#6726
Just my opinion , I have been known to actually race rc cars though
#6727
You will hear a few different opinions from different groups but imo one of the most suited pipe combos for that engine or almost any engine in buggy is 2096/41021 , use 8mm for first 1/2-1 gallon of fuel (more air , more fuel, more oil) then I would recommend a 7mm restrictor unless you wanna try a 6.5mm up to you
#6728
#6729
Hello, has anyone ever experienced a novarossi clio p5? Information on who is running this engine! This engine is good for truggy? What better exhaust and manifold?
I am looking to buy for my truggy.
I'm in doubt between a motor 5 or 7 ports!
Clio p5 or keep-off 7?
Any help will be appreciated!
thank you
thank you
What about the new clio p5 in truggy Ty?
ThANKS FOR THE HELP
#6730
#6731
There is only one way to do Hard Anodizing "right" and that is to leave it uncolored/undyed and naturally gray like the factory-finish pipes you remember. It's a smooth gray/lacquer gray depending on the alloy. That color is just a byproduct of the process and will always maintain that color tone.
You can dye a HA part black, but the dye eventually leaches out like you saw/experienced before. Because the cell structure is smaller/tighter in the TypeIII process, the dye doesn't stay in as well as regular Type II process (colored anodizing). Thus you get the "bronze" look since the natural color is basically ergal gray.
http://www.rctech.net/forum/r-c-item...-sets-new.html
#6732
#6733
Guys I am trying to figure out what size bearings the mugen BT4 and BT5 use front and rear?
From my research it looks like the BT4 Uses the 17011 Front 7x19x6.3 and the, 16800 14x25.8x6 Rear
The BT5 I can't seem to find an exploded view on so I looked at the view of the P5XLT and it shows the same bearing setup as the BT4 but I know that cant be right because the front bearing in that motor looks nothing like the front bearing in the BT4. If I am correct I believe both motors use the 16800 rear bearing but please correct me if I am wrong. I am trying to place an order so I have the bearings on hand just in case one goes.
#6734
the front bearing will work, its a patented design by novarossi, just be careful when putting it in the engine, because its a 6.3 the inner race protrudes, and you will want to put the force on the outer race not the inner to insert it..
not sure of rear bearing size
just found the exploded view that i have.. its the same rear bearing
352Likes
