NOVAROSSI Engine thread....
#6706
Plus 4, c6tgc, 9901, 41021. Quick question: tuning
Motor up to temp, clutch just rebuilt, new fuel line, new plug, new fuel (sidewinder v2 30%), running a 6.5 restrictor. Top end needle about 1/2 to 1/4 turned in from flush, idles fine, bottom end doesn't drop off, pinch test about 1.5 to 2 seconds it reacts (goes lean), throttle servo set up perfect (returns throttle fully closed and opens a hair past the restrictor looking down into the carb), .5mm dead band on throttle linkage. All that being said, I run my buggy around and do a semi high to high speed pass and get on the brakes and it flames out.
What the heck? Please give me some ideas. Please....
#6707
You could also try someone elses fuel, as you may have a bad batch.
Could also try a C5 plug if you have one laying around.
#6708
I just started using it. I have roughly a gallon through the motor with S&W 30% (green), and I just bought a gallon of Sidewinder Strike Team V2 30% (clear).
I think it's gotta be bottom/idle. Plug is brand new and glows on igniter fine.
Puzzled
Puzzled
#6709
Has anyone ever used a EB Mods Power Plate on one of their Novarossi motors? Got a friend that is selling a motor with one installed and he claims they actually increase power and run time. Dont really care about the power increase but I am curious about the increased run time claim. Seems far fetched so I thought I would ask. http://www.absolutehobbyz.com/produc...ducts_id=13479
#6715
#6716
Just wondering if I need to adjust the head shims on a .21 P5XLT if I am runinf 30 % nitro. The manual is kinda vague just referring to the "exploded view". The way I read the manual 25-33% nitro run the standard shims? Just a bit unsure any help would be much appreciated. I would just run 25% but I was running 30% in my last motor and I would hate to waste 1/2 a gallon of 30% fuel. Thanks so much!
#6717
#6720
on our track conditions there is no other combo worth running but a 9886/41001/41019 on a stock or modified Bonito...this combo gives the best bottom end kick with the largest overall powerband... SO if you are running on higher traction I wouldn't be looking at a 2084 or a 9853 or a long manifold...maybe its great for slick tracks, but for anything like what we have those combos are not that good.....The very first time I tested a Bonito it was on a 2084/41005 and my first thoughts were that no wonder nobody likes these engines as it had no pop whatsoever. But as soon as a 86 and short manifold were put on the engine woke right up with all kinds of bottom end power and snap.... true story ![/QUOTE]
Neal. would this be true for the keepoff 7 as well,which of the manifolds
would be first choice for good bottom end and throttle response out of
the 2 you recomend.
thanks rick..
the 2 you recomend.
thanks rick..
352Likes
