Like Tree352Likes
NOVAROSSI Engine thread....
Old 06-19-2012 | 02:22 PM
  #3196
Dr. Evil's Avatar
Talking Which pipe/header/glow plugs to buy
Good day folks. I am thinking of purchasing my first Nova Rossi engine.
I am looking at the P5XLT to run in my Mugen Buggy, Serpent 811 Buggy and Mugen Truggy and want some input.
Which Header/Pipe/glow plugs should I use in this engine.
What can I do to get the highest fuel economy from this engine.
General track conditions are a medium size track, several sharp turns so coming out of th hole is important.
let me know what you think please.
Dr. Evil
Dr. Evil is offline
Old 06-19-2012 | 04:35 PM
  #3197
Teufel Racing's Avatar
Dr. Evil
E, you should call a brotha.
Pipe and header are: 2096 and 021 header (029 for the newer Mugens)
Plugs: C5TGC and C6TGC.
Fuel Ecco? Wouldn't worry too much. The XLT will get 10 minutes plus in stock form. At the track you'll be running it at, I'm pretty sure you won't have an issue. Get a 17011 front bearing for it and it's good.
Now just pull the trigger and get that new mill. You'll be gald you did.
Teufel Racing is offline
Old 06-19-2012 | 05:54 PM
  #3198
Dr. Evil's Avatar
Default New Engine??
Damm..
You're always there..
Cool.
Pulling the trigger is easy, except when there is a sharp turn/wall there in my way. LOL Talking about my driving..
Anyway.
I'm working on it. Amain keeps changing the price. The price changed 4 times in the last 2 hours. Price was cheaper than the last place you told me then the price went above, then back below.. Crazy..
BTW - The Mugen MBX5T is dead... headed to the retirement shelf. I pulled the motor/transponder out Sunday Night and put them into the MBX6T. I'm trying to bring the MBX6T online. Need a few things. Hope to have it done in 3 weeks.
As for the engine, so far the 5xlt looks great as you mentioned. Just looking for opinions.
Ahh as a mod, should I get a silicone filled crank??
Dr. Evil is offline
Old 06-19-2012 | 06:21 PM
  #3199
beidle99's Avatar
go here http://www.houstonsengineservice.com/ The price doesn't change and Monty takes care of his customers.
beidle99 is offline
Old 06-19-2012 | 06:23 PM
  #3200
mjealey's Avatar
So I snuck away tonight and spent 2.5 hrs. with this motor.........100% no go. Just for the heck of it I set the needles to 3.5 HSN and 4.5 LSN and ran it. Really bad lean bog, and ran so-so on top once you got it rolling and got some fuel in it. So I tried to keep richening the top just to see how far I could go with it to get rid of the bog. So the HSN is 4.5 out now just to experiment and the low end is almost there and but it is too rich on top and will not stay running. If it is on the starter box and you blip the throttle it will barely bog, then settle into a nice idle for 2 seconds then the rpm will pick up and just shut off after 8 seconds at 4.5 and 3.5 on the needles...... Runs out of fuel, lean! Really erratic idle.
So I ended up at 5.25 on the LSN, and 3 on the HSN. Only way I could get any kind of snappiness and crispness out of it, running 280 to 300 at these settings, but it is really crisp will idle nice and smooth and run all day. I guess I am not going to worry what one of these motors "should" come close to running at and just run and race it there. I put the OS Speed in just to check with the same pipe, same everything and no problems at all. I just hate that I can get 8:30 to 9:00 minutes out of it at these settings. Tried all different pipes to no avail!!!!!!! Spray motor clean all on the front bearing while it is running and has "zero" effect on the idle.
I am going to replace the front bearing in it just to be safe and run it where it runs best!!!!!!!!
mjealey is offline
Old 06-19-2012 | 08:31 PM
  #3201
megasaxon's Avatar
the 2084 and 9901 run great on the p5xlt as well. same deal, 41021 short or 41029 short(tight bent) header with these pipes
I personally run the 2084/29 combo on my p5xlt in my MBX6R and love it
megasaxon is offline
Old 06-19-2012 | 08:58 PM
  #3202
houston's Avatar
2096ss/41021 is the goods on the p5xlt
houston is offline
Old 06-19-2012 | 11:10 PM
  #3203
Dr. Evil's Avatar
Talking P5XLT
Good to see what people think.
Nice to know there are people that think alike.
I think I'll go with the P5xlt with 096/2096.
Thanks Teufel and all.
Dr. Evil is offline
Old 06-20-2012 | 08:40 AM
  #3204
CanyonCarverR1's Avatar
Originally Posted by Sprinkler
My 21-4BTT came in on Saturday. It was like a light switch. Temps dropped 25 degrees, instant drop to idle and pulling harder then ever on top now. Awesome!!!!
How much fuel did you have through it?
CanyonCarverR1 is offline
Old 06-20-2012 | 10:42 AM
  #3205
Dr. Evil's Avatar
Talking "Houstson Tuned"
Hi. Not trying to sound like a pill here and I am not trying to ask for
trade secrets either. Just want to know what you get when something is
"Houston Tuned"
Are we talking smoother idle, smoother (less like a light swtich) throttle
More fuel economy, Smoother bottom end, Higher revs (etc, etc, etc)???
What does one get.
Again, I don't want to know how it's done or any company secrets, just want to know what to expect for the price.
Dr. Evil is offline
Old 06-20-2012 | 12:07 PM
  #3206
omarwashington's Avatar
Originally Posted by kgombe
and i have to agree...
what Manifold would be good?
omarwashington is offline
Old 06-20-2012 | 12:34 PM
  #3207
"Houston Tuned"
What does one get.
E,
I'll call you in a bit
Old 06-20-2012 | 01:33 PM
  #3208
Motorman007's Avatar
Originally Posted by houston
At this point no
It is available buttttt price is wellllll a bit much for a carb
Novarossi has always been at the head of the game in the carb world
How much are the novarossi 24065 carb ?
Found it
http://www.absolutehobbyz.com/produc...g68qsm5k1sch30
Motorman007 is offline
Old 06-20-2012 | 07:55 PM
  #3209
revo61's Avatar
How does the 2096 compare to the Losi RE12 pipe?
revo61 is offline
Old 06-21-2012 | 02:43 AM
  #3210
savannahmick's Avatar
I just recently got a RE12 and it's the same as a 9901 which is a great pipe for most Novas. My buddy runs a 2096 and he told me that it's just a little smoother and easier to drive than the 9901 but they are both great pipes. The RE12 is about half the cost and less likely to get bent than the Nova pipes which are easier to bend or dent IMO.
savannahmick is offline
