Like Tree352Likes
NOVAROSSI Engine thread....
Old 05-27-2012 | 08:29 PM
  #2881
mjealey's Avatar
Hey guys, once again there are a lot of factors but I am just curious of 2 things. I am running a Plus-4btts, 30/9% Byron's, 9886 pipe, c6tgc plug.
1. What length of pressure line should one be running on one of these Nova's? MBX6r buggy
2. In general how many turns in should the LSN be on all out race tune? 4.5t?
I know a lot of variables but just generally speaking with these Nova's.
mjealey is offline
Old 05-27-2012 | 08:35 PM
  #2882
houston's Avatar
8 inches minimum and you are pretty close on lsn , sometimes there are some weird factors that can change things up but 4.25 is very close , maybe even 4 turns with dyn086hs
houston is offline
Old 05-27-2012 | 08:41 PM
  #2883
mjealey's Avatar
Thank you very much. I am right there and running good just more of a curiosity question than anything!!!!! Thank you much. If you say minimum of 8 inches, is more in the 10 inch ball park better?
mjealey is offline
Old 05-27-2012 | 09:38 PM
  #2884
sickpuppy1's Avatar
I know, its not a screamer, But it seems to be doing "OK". Good enough to get my feet wet so to speak. Just tryin to get a feel for what pipes work best for it.Of the ones I have I guess I'll go with the JP3. Thanks
sickpuppy1 is offline
Old 05-28-2012 | 04:23 AM
  #2885
shimano's Avatar
I'm not reading much on the Roma .25. Is no one running them?
shimano is offline
Old 05-28-2012 | 07:18 AM
  #2886
Dear all, want to ask the best pipe for nova 4plus btt ? For overall performace and fuel efficiency . Thanks
Hartw is offline
Old 05-28-2012 | 07:25 AM
  #2887
aznitronut's Avatar
I have been using the Nova Rossi 2096/021 pipe and header, the 9901/021 also works well. Fuel mileage, depends on what your using in, buggy should get 10 minutes easy, and that depends on track layout, and size.
aznitronut is offline
Old 05-28-2012 | 07:30 AM
  #2888
Quad Racer 34's Avatar
Yes I run one. It a great engine! VERY fast! I run it in my truggy. I've have about 3 races on it now. The first race was an indoor race for our regional pro series. I was able to pit at 10:30 without a problem. Now last weekend was an outdoor race on a track I was comfortable with so I was driving the truggy STRAPPED! lol. I was only able to go about 8:30 with it so I pitted at 7. But its a very good engine.
Quad Racer 34 is offline
Old 05-28-2012 | 07:57 AM
  #2889
Jaz240's Avatar
Does anyone have a link to replacement screws for the back plate and cooling head of a P5? I want metric cap head not these horrible slotted flat heads... TIA
Jaz240 is offline
Old 05-28-2012 | 07:59 AM
  #2890
rider313's Avatar
I was thinking the same thing.
rider313 is offline
Old 05-28-2012 | 08:03 AM
  #2891
air8's Avatar
Backplate screws are 2.6mm....same as Hitec servo horn screws. And I've never checked the cooling head screws.
air8 is offline
Old 05-28-2012 | 08:23 AM
  #2892
megasaxon's Avatar
the cooling head screws are 3.5mm
http://www.tonysscrews.com/product.s...&categoryId=53
I personally like the flat head screws better than the hex screws. I've stripped out more hex heads than flat heads. If you have a good screwdriver, the flat heads work nicely.
megasaxon is offline
Old 05-28-2012 | 08:26 AM
  #2893
Jaz240's Avatar
Cool I got lots of those! Think I'll just try some cooling head screws from other engines and see what fits. I'll report back
Jaz240 is offline
Old 05-28-2012 | 08:43 AM
  #2894
aznitronut's Avatar
Some of the other engines have different lenghts than others, why do you need to remove them so often?
Old 05-28-2012 | 08:46 AM
  #2895
Chad Millikan's Avatar
A while back on this thread, I read that the RB ones work for the back plate.
Chad Millikan is offline
