Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Houstons Engine Service H.E.S. >
Like Tree22Likes
Old 05-10-2009 | 09:25 PM
  #466
Trevor Williams's Avatar
R/C Tech Elite Member
Originally Posted by houston
are you getting antsy pantsy . i have many more also yo
nah, not really man, but I am interested in that RB Mods JP you told me about.......rocket yo
Trevor Williams is offline
Old 05-11-2009 | 12:57 PM
  #467
what are the differences between the FMS and Toro. are they very similar or very different? thanks
franklucas is offline
Old 05-11-2009 | 10:28 PM
  #468
houston's Avatar
quite a bit different actually , ports are different , bore and stroke are different , its just a different engine . the fms is badass
i have two available
houston is offline
Old 05-11-2009 | 11:32 PM
  #469
houston's Avatar
http://www.rctech.net/forum/5397376-post1.html
houston is offline
Old 05-12-2009 | 12:48 AM
  #470
losi_racer's Avatar
hey monty, im gettin a +4 off a main due to coupons and credit there im gettin it for like 280 shipped but its on back order so gotta wait. but anyway
i plan on using a p3 plug is that ok? or should i use a p4... and whats a good pipe/header for this engine for around 50-60
losi_racer is offline
Old 05-12-2009 | 09:57 AM
  #471
houston's Avatar
do not use os plugs !!!!!!!!!!!!! use novarossi or odonnell plugs
ofna 053 pipeset is awesome , i have three in stock for 60$
and btw that is cheaper than cost and hope you get one with the extra combustion chamber
take it easy ,
monty
houston is offline
Old 05-12-2009 | 01:57 PM
  #472
cweb's Avatar
i dont feel that is an important part of your engine setup. doesn't really make a difference in anything that i have found , just dont max out your epa on the hi throttle and you should be just fine
Thanks Monty, I'm runing in a ROAR regional at my home track in DE. and want everything to be perrrrrrrfect.
cweb is offline
Old 05-12-2009 | 02:14 PM
  #473
houston's Avatar
i got a customer named dave alfree over in delaware . tell him hi if you see him
thanks , monty
houston is offline
Old 05-12-2009 | 02:52 PM
  #474
Hey Monty,
did you get my pm?
Thanks,
Rudy Diaz
Deznuts05 is offline
Old 05-12-2009 | 04:23 PM
  #475
I have a quick question, I have been running my +4 going on a gallon now. It is not completely broken in as the temps have not dropped and it is still a bit "sticky" up top without a plug in.
The issue I am having is that it is dying out at the end of the main straight. The settings are the same on the needles and it is running 225-235, the only thing that I have changed is to replace the stock Novarossi #5 plug with a 099. I am about to try the 077 to see if it is any better. When I do an idle test about 2" from the carb it dies after about 4 seconds.
How does the temp of the #5 compare to the 099 or 077? Would you recommend going leaner ar richer on the low end? It nearly seems like it is loading up, but I don't want to go too lean on the bottom either. Thanks
USP45 is offline
Old 05-12-2009 | 04:28 PM
  #476
Monty,
if I pair a Dynamite round header with my Ofna053, what can I expect performance wise vs. the Ofna square that comes with the pipe?
thank you fo' yo' time yizzo'
Old 05-12-2009 | 05:00 PM
  #477
houston's Avatar
odo99 is ultimately cold , you will be much closer in tune with the odo77
should not die if tuned in properly
houston is offline
Old 05-12-2009 | 05:02 PM
  #478
houston's Avatar
Originally Posted by Trevor Williams
Monty,
why would you do that ? might be ok for a really really small track , the overall balance of the pipe feels better with the square header .
i need to get rid of some engines guys .
houston is offline
Old 05-12-2009 | 05:15 PM
  #479
not saying im gonna...LOL....i was asking what the difference would be
Old 05-12-2009 | 05:51 PM
  #480
houston's Avatar
plus 4 engines fms engines and everything else ,
what would you like ????
houston is offline
