Houstons Engine Service H.E.S.
#1217
Re slotted screws, especially the cooling head one, I picked up a Profi-Tool by Hudy a few years back which is purpose-design for Nova head screws. It shouldn't cost more than $10, it's a 5.8mm tip that falls RIGHT IN the Nova's screw heads. Insert it in the whole, turn gently, TICK, there you go. One of the smartest ideas from Juraj, really (this and the spring pulling tool
Hi Monty,
I have a question about sleeve pinching - what this essentially does is squeeze matter to reduce the inner sleeve diameter, right? But this matter has to be coming from somewhere... namely the outer side. Hence my question: once the pinching is done, the fit of the sleeve in the case can't be as perfect as before, which means the sleeve will be able to move (radially, at least) around (even if a tiny bit) or at least vibrate (as it should be kept in place axially by the plug insert), how much risk does this represent for an engine revving at 30Krpm?
Regards,
Paul (still learning the ropes of IC engines...
)Hi Monty,
Regards,
#1218
#1219
lonestar ; in testing the sleeves resized by rayaracing (they were done very well) i did not notice any leakage in the area around the sleeve and the fit in the block . some even had a better fit after they were done by ray
#1220
#1223
he has two cranks of mine to do .
#1225
#1227
#1230
Houstons Engine Service Novarossi Plus 4 takes 12yr old Cade Whitenton to the TQ and 1st place win in Intermediate 1/8th Buggy and TQ and 1st Place win in Intermediate Arena Truck at the Region 9 ROAR Offroad Fuel Championships August 1st.
Thanks for the Plus 4 in the buggy Monty. The motor is off the hook and still not broke in yet. That is two in a row with SMOOTH NOVAROSSI POWER!!!!!
Jon
Jon
22Likes
