Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Houstons Engine Service H.E.S. >
Like Tree22Likes
Old 03-17-2010 | 05:10 PM
  #2716
jonw's Avatar
Thanks. I will contact him tomorrow.
jonw is offline
Old 03-17-2010 | 09:27 PM
  #2717
Hey Houston, will a p4 work ok in a fms? I have only p3s and 1 p4 left and wanna run the fms tomorrow. Thanks in advance.
Matt Piva is offline
Old 03-18-2010 | 06:24 AM
  #2718
Houston....we have a problem......
ok so I broke in a n21r... did the whole heat cycle method, still has a little metal pinch, blah blah blah..
anyway when I go to full throttle it cuts out and dies..
things I have done to solve it,
changed tune on top from 3 out to 5 out and everything inbetween
changed tune on bottom from 3 out to 5 out and all in between
changed shimming to 2 silver 2 copper and stock shimming
changed pipe from go2047 to re-10
changed fuel line
changed plug from stock to OD 99 to mc59
took apart and sealed everything
changed clutch 3 times even to different brands
any ideas?? it runs good till I get to the top end then it sputters and pops and dies. like I said I went lean to fat on top..
any help would be great
TheTopic is offline
Old 03-18-2010 | 06:25 AM
  #2719
I am sorry I should also post this is not an engine that I got from you as I was in a pinch for a race this weekend and needed one asap, I just know you are the guru of Nova engines and needed some help
TheTopic is offline
Old 03-18-2010 | 07:15 AM
  #2720
revo61's Avatar
Did you check the fuel tank for leaks?
changed fuel line
revo61 is offline
Old 03-18-2010 | 07:24 AM
  #2721
houston's Avatar
It sounds as if you have trouble shooted any issue the engine might have so move on to other parts of the equation .
My thoughts are that the problem is the fuel .
This is exactly what happens when you either have an old bottle of fuel , a really low nitro content fuel (like 5% heli) or your engine is grossly mis shimmed .
Try a fresh bottle of byrons and let me know what happens .
Remember this , just because you get fuel from your lhs doesn't mean its fresh , they could have left it sitting in back on a concrete floor for six months before you bought it and that is not good !!
Btw , I am no guru , I just know a few things
houston is offline
Old 03-18-2010 | 07:29 AM
  #2722
Trevor Williams's Avatar
R/C Tech Elite Member
you big GURU of a man you!
Trevor Williams is offline
Old 03-18-2010 | 07:31 AM
  #2723
teamlosi906's Avatar
Default nova
question i bought a 21p5xs motor not to long ago the guy i got it from sent it for warranty new p/s and rod but the case looks like my p5 xlt with the stronger looking case, turbo crank ,standard glow plug ,with a p5xs head confused on what the difference would be if any thanks for your time
teamlosi906 is offline
Old 03-18-2010 | 07:37 AM
  #2724
houston's Avatar
Not 100% sure what your Q is but the only difference between the xs and xl is the head . Yes this is the truth !! Why change a killer engine ?
Turbo crank? Hmmmmm
There is supposed to be a new p5xlt "tuned" sometime in the future but until then I will just make them myself . I think most are happy with my 5 ports
houston is offline
Old 03-18-2010 | 07:55 AM
  #2725
Default p5
Turbo crank? Hmmmmm
thanks but my other p5xs didnt have the longer mounting flanges like this 1 and the crank is also different is it a newer p5xs thanks again
Old 03-18-2010 | 07:58 AM
  #2726
losiracer78's Avatar
I dont know anyone thats not happy with a Houston Motor I know i love them And Cant wait to get the new Plus 4c broke in and on the track
losiracer78 is offline
Old 03-18-2010 | 08:01 AM
  #2727
houston's Avatar
The 2008 and newer p5xs have the thicker mounting tabs
Yes they are internally identical , unless you have one of the very first xs engines that didn't have the lightened crank or novarossi or somebody along the way just threw a different crank in there . I have seen many of these engines
houston is offline
Old 03-18-2010 | 08:04 AM
  #2728
Default p5
thanks alot also sent you a pm
Old 03-18-2010 | 09:39 AM
  #2729
houston's Avatar
hope i answered your Q's satisfactorsilly
wierd morning
houston is offline
Old 03-18-2010 | 09:52 AM
  #2730
wierd morning
Hey Monty 1 more ?, p4 in my fms is ok for 1 day of driving till I can het an od tomorrow? It's all I have and 2 p3s.
