Houstons Engine Service H.E.S.
#2566
keep a good eye on your clutch bell bearings
make sure carb is pushed all the way in and locked in well
make sure your air filter doesnt leak any where and is well secured to the engine
use throttle return bands such as pictured
#2569
the older bf you are refering to has a 13mm crank , a crappy metal carb , a different rod(07030) as well as a few other differences . you must use the parts that came with this engine
the n21r and n21bf will accept the 14mm 15009 , 15009t or 15007t cranks for a huge gain in performance . the R7 rod is also a direct replacement for the n21bf and n21r
#2570
the n21bf limited has a 14mm crank and is the same borexstroke as the p5 and plus 4 as well as many other nove engines .
Is any sleeve work neccesary to make it into a beast ? how about a turbo button under the head?
#2571
sleeve work can enhance performance of course when done right , the crank replacement can really increase performance , a turbo underhead #28002 can also create more performance as well as ceramic bearings . replacing the E1 rod for and R7 will aid in prevention of rod failure .
#2572
Yes i was refering to the BF and NR, but also to engines in general. I wonder what the cuts in the sleeve help the engine to do, you know raising port windows and I guess you should lower the exhaust ports and i wrong
#2573
there are many ways to manipulate fuel flows , entry timings, angles and exhaust exiting to create different powerbands
#2575
i really dont know 100% for sure which engines are made by whom for RB , to me it would be easily distinguishable by seeing the engines to say whether or not they were made by novarossi or not .
if somebody who knows for sure what engines are made where for RB then please feel free to chime in
It is just like Maximo said, The K9/K10 are the only engines made in Taiwan. The Shark9, the B10 coming out and the Cross10 coming out are still made by Nova.
#2576
#2577
Suspended
ih houstons i ask you about the turbo toro nero head button here's my email [email protected]
#2579
I will email you payment details right now
#2580
Novarossi was using the extra blocks and casting leftover from the discontinued s821b 8 port engine . Now they have exhausted those they are using the standard 5 port block . The n21r is a pretty dam good budget engine IMO and with a little work
Hope this helps speedy
Viva la novarossi !!!
22Likes
