Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Houstons Engine Service H.E.S. >
Like Tree22Likes
Old 02-27-2010 | 04:00 PM
  #2581
Quick question. I've been breaking in my new +4C. I've put about 13-15 heat cycles on it using "the break-in bible" method. Then put 2 more heat cycles @ a tank each. Ran it fairly hard the last 2 tanks. It still has tons of pinch. Think it's ok to start track tuning it for the rest of the break-in?
Miniracer23 is offline
Old 02-27-2010 | 04:30 PM
  #2582
KWT-NITRO's Avatar
am not Monty but just my 2 cents, after what you have done already, i would track tune it and keep the temp around 220-230 and run it untill it richens by itself, just monitor the temp frequently not to run on the lean side and dont let it go out of fuel.
cheers
Ali
KWT-NITRO is offline
Old 02-27-2010 | 08:45 PM
  #2583
r1harper's Avatar
is the 2013 decent on fuel..want to try one
r1harper is offline
Old 02-27-2010 | 11:28 PM
  #2584
houston's Avatar
no but tons of pooop
houston is offline
Old 02-28-2010 | 12:59 AM
  #2585
Trevor Williams's Avatar
R/C Tech Elite Member
Trevor Williams is offline
Old 02-28-2010 | 08:19 PM
  #2586
houston's Avatar
power
houston is offline
Old 02-28-2010 | 09:04 PM
  #2587
What glow plug should I be running in a Nova P5?
JD33 is offline
Old 02-28-2010 | 09:45 PM
  #2588
and it was a fuel pig........
Jerry, for your p5x get some Odonnell 77's and 100's
Monty.....what venturi was in your STrr with plus4 that day I was running it?
Old 02-28-2010 | 09:56 PM
  #2589
houston's Avatar
7.5mm
Like trevor said on the plugs
houston is offline
Old 02-28-2010 | 09:59 PM
  #2590
cool..........what did you do under your fuel tank on truck yo?
Old 02-28-2010 | 11:13 PM
  #2591
houston's Avatar
10th scale foam cut to about 5/16th" thick and the shape of the bottom of the fuel tank
houston is offline
Old 03-01-2010 | 11:01 AM
  #2592
am
So, Monty.
What was the Nitrotec....
am is offline
Old 03-01-2010 | 10:50 PM
  #2593
houston's Avatar
The 9886/41020 can be less top than what you might think .
TRY the 41021 header or dynamite 086hs pipeset
Ran a 9901ss/41005 header this week in the buggy and it worked pretty well
Got to visit for an hour with bernard durand and hope to keep the lines of communication open there
We both understood each other very well , he was very interested in my ideas and opinions
I found out what the nitrotec engine is , if you have an n21r and you put a 15009 crankshaft in it out of the p5xl and you put a head from a plus4 you got yourself a nitrotec !
Sittin at the airport now waitin for the plane , kinda bored
Btw , that engine should riippppp with the right pipe Wes .
I made it the same as the ones I made for Ali in kuwait , he is very impressed with it and I hope it lasts him a long time .
Has anybody heard of some guy who calls himself mojo mods ? If you have , get a hold of me .
Happy motorin',
Monty
answer here
houston is offline
Old 03-02-2010 | 02:33 AM
  #2594
am
Hi Monty and thanks.
Did you get to talk to him abaiut the new pipe for buggys?
What is the Nova partnumber for the piston/sleeve of the N21R?
Anders
am is offline
Old 03-02-2010 | 05:41 AM
  #2595
jonw's Avatar
Hey Monty
Both motors ripped this past weekend, couldn't be happier. Want to make the switch to Byrons though, what do you suggest?
Jon
Cade say's "What's Up?"
jonw is offline
