Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Houstons Engine Service H.E.S. >
Like Tree22Likes
Old 03-03-2010 | 01:09 PM
  #2611
Gixxer2k4's Avatar
Houston,
do you sell the nova motors? If so can you email me a price list of what you have? [email protected] Thanks Troy
Gixxer2k4 is offline
Old 03-03-2010 | 04:52 PM
  #2612
CKmaxx's Avatar
He has a website and online store..
www.houstonsengineservice.com
CKmaxx is offline
Old 03-03-2010 | 05:47 PM
  #2613
houston's Avatar
What engine do you want ?
houston is offline
Old 03-04-2010 | 02:53 AM
  #2614
thank you guys ,anyway one more thing about the p5s ,is the shim the same as the bf limited or different ???,my friend currently using the 20% nitro this is the same guy that im talking about early about the glow plugs get busted all the time ,today he told me that he went & check the nova bf & the conrod was shot ...once again please hes last mill (p5)any input guys well appreciated
mbx5rcr34 is offline
Old 03-04-2010 | 08:17 AM
  #2615
houston's Avatar
Yes the shims are the same
I was pretty sure it was the rod
And I have no idea what your other question is
houston is offline
Old 03-04-2010 | 08:44 AM
  #2616
Houston,
I am running a N21R with the 41020/9886 combo with 25% and an od77 plug. I have noticed you mention a new crank is a nice way to increase power w/o modding, what kind of power gains are we talking about here? Is it worth dropping $120ish on a new crank (plus $55 on new ceramics, might as well have you put em in while you have it) on a $135 budget motor? What crank would you suggest to work best with the header/pipe combo I am running. I like the 9886 but want a little more bottom end hence the long header, is there a crank that would fit this application? Thanks!
C.Harper is offline
Old 03-04-2010 | 08:56 AM
  #2617
houston's Avatar
Originally Posted by C.Harper
Houston,
It wouldn't be a budget engine when you were done with it
More bottom end ? Hmmmm , that's weird you say that cause I have noticed very good low end throttle response from these engines even in stock form with 9886/41021 or the dynamite 086hs pipesets . If you really feel you are lacking on the bottom then try a 9853ss or 9901ss with 41005, if you still think you are lacking low end , use a 41021 header on either pipe .
And I would probably drop a 15007t crankin it or 15009t or HT crank
as far as the differences in power , you won't even believe its the same engine
houston is offline
Old 03-04-2010 | 02:47 PM
  #2618
KWT-NITRO's Avatar
Hey Monty,
Am i representing or what?? check the sticker
cheers
Ali
KWT-NITRO is offline
Old 03-04-2010 | 04:42 PM
  #2619
speedy G's Avatar
What crank would do the same for the n21bf??
speedy G is offline
Old 03-04-2010 | 06:13 PM
  #2620
houston's Avatar
n21r and n21bf are close enough to be called the same engine
houston is offline
Old 03-04-2010 | 06:16 PM
  #2621
Monty,
You ever get that order in w/ the pipes, or are you still waiting.
Shaun
Miniracer23 is offline
Old 03-04-2010 | 06:26 PM
  #2622
houston's Avatar
Originally Posted by Miniracer23
Monty,
Shaun
its going to the p.o. tonight
houston is offline
Old 03-04-2010 | 06:40 PM
  #2623
You're awesome man, don't forget to send some decals...I like decals.
Old 03-04-2010 | 08:33 PM
  #2624
houston's Avatar
White , yellow or orange ?
houston is offline
Old 03-04-2010 | 09:07 PM
  #2625
Trevor Williams's Avatar
R/C Tech Elite Member
what no pink??
Trevor Williams is offline
