Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Houstons Engine Service H.E.S. >
Like Tree22Likes
Old 05-07-2009 | 02:30 PM
  #436
NITRORULES's Avatar
monty ,thanks for the pm, the price is great for the motor,pipe combo for my 8t 2.0,just got my 8 2.0 today,my better half requested that i wait a week before i dump another chunk of $,so i will pm you in about a week,thanks for returning my pm so fast, Brad
NITRORULES is offline
Old 05-07-2009 | 03:12 PM
  #437
Lonestar's Avatar
Hi again Monty
I have a noob question for you... what is the size of a new crankshaft rod-connecting nub on a v-spec - is it 5.00mm? Mine is at 4.95mm horizontally and 4.91/4.92mm vertically. Could it be the reason why my v-spec is impossible to set up?
thanks for the help - sorry the sale eventually didn't happen. Next time $
Regards from switzerland,
Paul
Lonestar is offline
Old 05-07-2009 | 04:37 PM
  #438
houston's Avatar
Originally Posted by Lonestar
Hi again Monty
Paul
its all good
if you rerod at 4.92 you will get about another 2-3 gallons out of the crank but that will be the last time you can do that
i reference all my engine dealings to novarossi , i really dont know how long a vspec will last after doing this , 4.97-8 is new . cant be too tight as it needs to have room for lubrication
houston is offline
Old 05-08-2009 | 12:22 AM
  #439
Lonestar's Avatar
Originally Posted by houston
its all good
Monty
thanks for taking the time to help - please help me make sure I understand this properly - you're recommending to get a new rod for this mill? Piston/sleeve looks fine, the piston still cannot travel "through" the sleeve and stops pretty much where TDC is. No cosmetic damage on the piston/sleeve, at least no scratches I can see.
Can you please confirm I read this right? And could you maybe try to explain howcome this mill is already so worn out despite being only through 1 gallon of good-quality 25%? It might have overheated above 250F a couple of times, but it was always treated respectfully with new air filters pretty much every liter...
Paul
Lonestar is offline
Old 05-08-2009 | 10:13 AM
  #440
houston, with my engine up to temp and when sitting at idle it will begin to idle up after 3-4 seconds but continues to run. Is my low end needle set wrong ? Is it too rich and loading up ? Any and all help is very appreciated. This is my first mill and Im learning by the hour. Thanks for responding to my earlier question also.
roadracer43 is offline
Old 05-09-2009 | 01:03 AM
  #441
Allumina's Avatar
Chiming in for my main man Monty...he'll be out of town for the weekend fellas, so hang tight he'll fix you up when he gets home
Allumina is offline
Old 05-09-2009 | 04:45 AM
  #442
Trevor Williams's Avatar
R/C Tech Elite Member
GL this weekend Monty
Trevor Williams is offline
Old 05-09-2009 | 01:18 PM
  #443
I know that Monty is out of town, but somebody else might be able to help.
21-4 roughly 1/2 gallon
set to run 225-230
original Novarossi plug, have 077 and 099 with me
It runs well, accelerates great off of the bottom, but down the straight is stuters or hesitates for a second and then picks back up. I would think that this is telling me that it is lean up top, butlike I said it is running in the correct temp range.
Any suggestions? I am at the track now and have a race tonight. Thanks
USP45 is offline
Old 05-10-2009 | 03:50 AM
  #444
houston's Avatar
your low end is more than likely not set properly , probably too rich on bottom and over compensating with wide idle gap . or it is too lean on the bottom . if it makes a tingy sound then the bottom is too lean .
it could also possibly be an air leak , usually around the carb lock if there is an air leak . caused from a ripped crankcase lower carb seal oring .
houston is offline
Old 05-10-2009 | 03:54 AM
  #445
houston's Avatar
set to run 225-230
interesting
what pipe? is it stuttering after it starts hitting top ?
it sounds like the low end is very rich and it is taking a while to blow the fuel out of the crankcase though
houston is offline
Old 05-10-2009 | 03:55 AM
  #446
houston's Avatar
Monty
Paul
os is having some serious quality control issues right now .
i would stick another rod in the engine . use a new C-clip for the wrist pin
first round of oregon rcpro series ,3rd Qu. first place truggy ,TQ and 3rd place buggy (leading race for 25 min when steering servo didnt wanna work anymore IT WAS MINE )
houston is offline
Old 05-10-2009 | 06:54 AM
  #447
interesting
Actually, I came to find out that it was NOT the engine but the DX3S going into failsafe! It was mainly happening under WOT so I thought that it was the engine, and it is the second time it has done this (last week too). It finally locked out while turning before it went into failsafe so I had no seering for a split second and I figured out what was happening.
I did find a solution though......4PK!!
USP45 is offline
Old 05-10-2009 | 07:45 AM
  #448
What is the prefered pipe and manifold for the Toro Nero?
Nova 9901 with long manifold?
Dynamite 053?
Dynamite 086?
Best regards
casevac is offline
Old 05-10-2009 | 08:20 AM
  #449
GJ Monty, sorry about your luck in buggy.......hey man, btw.......what engine/pipe/ etc. did you run in buggy?
Old 05-10-2009 | 10:58 AM
  #450
houston's Avatar
awesome !! well kinda hope it all works out for ya
houston is offline
