Go Back  R/C Tech Forums > General Forums > Nitro Off-Road > Offroad Nitro Engine Forum
Houstons Engine Service H.E.S. >
Like Tree22Likes
Old 04-17-2009 | 08:08 PM
  #286
Hi Houston,
I have a backup P5XS (2008), and got it from a buddy. I am running a STRR, on medium size tracks. It has been a long time since I ran a P5.....what is a good restrictor to use (7 or 7.5mm?) and pipe for my tracks? I have a 2050, JP2, Dynamite 53, Dynamite 86, and MSR1005 pipe. I have a long header, a Dynamite header, the stock T2050 header, and what I think is a short ] shaped header (pretty sure it came from the MSR 1005 pipe, but it has been so long, I am not sure).
gtsum is offline
Old 04-19-2009 | 02:47 PM
  #287
stavman's Avatar
Yo Brutha
so whats gunna be the BEST pipe for the Toro Nero
9853
9901
stavman is offline
Old 04-19-2009 | 03:14 PM
  #288
cweb's Avatar
What is the EFRA # for on the pipe?
cweb is offline
Old 04-19-2009 | 07:21 PM
  #289
Eccentric's Avatar
What changes/improvements were made between the older 21-7 and the newer FMS? How is the performance different between the two? I may be able to pick up a low-time older 21-7 from a club member for a very good price. I'm looking to run it in a truggy in place of my RB TM928 as I won't be able to spend the $$$ on a new Nova for a few months.
Eccentric is offline
Old 04-20-2009 | 07:16 AM
  #290
Houston with everything being stock... What would be the difference in putting only a P5SX Crank in a BF limited??
Could you please explain what epoxy in a crank does.
njballa is offline
Old 04-20-2009 | 12:04 PM
  #291
tomdav's Avatar
Engine tear down today. Everything looks nice but I am wondering how much tolerance can there be on the rod. My crank pin looks good but the lower rod bushing measured about 5.00mm vertical and about 4.96/4.97 lateral. Is it time for a new rod?
tomdav is offline
Old 04-20-2009 | 12:16 PM
  #292
houston's Avatar
Originally Posted by gtsum
Hi Houston,
8mm restrictor , either dynamite 053mr w/ ] header or 086hs w/ )dynamite header . the msp 1005 is good also but i feel the dynamite pipes feel better . 053 on tracks where you guys have short run ups to jumps and dont have huge straights , 086 hs for fun screamin power
houston is offline
Old 04-20-2009 | 12:22 PM
  #293
houston's Avatar
Originally Posted by stavman
Yo Brutha
9853
9901
its lookin like 9886 w/ 41020 or 9853 w/41001 or 41005
i
houston is offline
Old 04-20-2009 | 12:23 PM
  #294
houston's Avatar
i forgot i will research though
houston is offline
Old 04-20-2009 | 12:28 PM
  #295
houston's Avatar
the 21-7 is a killer engine the fms is a revised version that has a few timing changes , ceramic bearings and a special crank . if that 21-7 is in excellent shape then it would be worth it for ya .
monty
houston is offline
Old 04-20-2009 | 12:30 PM
  #296
how did you do racing this weekend monty ?
PIGPENRC is offline
Old 04-20-2009 | 12:32 PM
  #297
houston's Avatar
the newer p5xs cranks are little lighter as they are drilled ,the epoxy gets rid of any turbulence pockets that could build up in the crank intake window. haven't really noticed any ill effects between filled/non-filled cranks though .
houston is offline
Old 04-20-2009 | 12:36 PM
  #298
houston's Avatar
warranty is over now , you took it apart
it shouldn't need a new rod but it wont hurt to put a new one in
086hs way better ? happy with the engine ? did you heat the engine up before starting in runin period , i know you usually do
houston is offline
Old 04-20-2009 | 12:38 PM
  #299
tomdav's Avatar
The 86 was perfect. It was heated for breakin but last weekend I was a little lax in my routine.
tomdav is offline
Old 04-20-2009 | 02:00 PM
  #300
SPEED37's Avatar
Hi Monty, my engine is here. Thank you. Great engine, better price, and service to boot. Cool if I call you? Have a question or two. Feedback left.
SPEED37 is offline
