Like Tree2Likes
Go-Tech Engines Thread
Old 03-13-2009 | 05:26 PM
  #5956
MassiveMods's Avatar
Originally Posted by vyt666
is this very 1st generation 5port engine im using?coz i dont know what are the differences between the 1st gen and the other gen thats been released by GO,but i think the carb is the revise one unlike the old one which is hard to adjust the idle stop screw coz its under the carb throat,im just curious about the different gen's of the 5 port
and what are the factory needle settings of this engine?
thanks!
Looks like a Gen 3 mid 2007 model to me ...
MassiveMods is offline
Old 03-14-2009 | 02:25 PM
  #5957
Ok this is weird i am asking a question LOL. I have always used the 8 and 7.5 mm venturi's swapping through out the day never having to touch the idle. Now I put my PTM in a buggy and am going with the 6.5mm does the insert affect the idle screw or not? Meaning should I put the venturi in then close the slide and do the 1mm gap or leave it how it was cause my needles never need played with.
malik is offline
Old 03-14-2009 | 03:27 PM
  #5958
tagalong_74's Avatar
Ok guys have a question for ya. Just broke in my new Go 21.7port turbo. runs flawlessly. Now that I took the alluminum foil off, I'm wondering what temps are normal for that motor because this thing is spot on and with the body on after a full tank ran through im only getting to 190 deg F? That amazes me and was wondering if thats normal or not. Thanks again guys
tagalong_74 is offline
Old 03-14-2009 | 04:37 PM
  #5959
Tree's Avatar
Set your idle gap without the venturi restrictor in the carb opening. Once you have it set, you should be able to swap out and use different venturis without havng to adjust idle only adjusting tune slightly.
Tree is offline
Old 03-14-2009 | 04:38 PM
  #5960
Tree's Avatar
optimally, you would want to keep the temps above 200 degress F.
Tree is offline
Old 03-14-2009 | 06:38 PM
  #5961
hi peoples
I'm looking for a new eng. and just found this Item number: 220373384347on the bay. I cant find much info on it, is it a good eng? what does the "factory mod" part include? I have run SIRIO NOVARISSI V-SPEC ect in the past how will this compare? thanks in advance.
backyardracer is offline
Old 03-14-2009 | 07:11 PM
  #5962
Backyard they are awesome, dont get that thats too much money they are just trying to sell you the stock 1 I have never heard of a factory mod, and I drive for them. I could be wrong but I doubt it. PM me and I can get you to the US sourse. About my idle adjustment Q earlier I was only asking because I always ran the 8 and 7.5 with no need to adjust the idle screw, but going to the 6.5 I was just wondering never used such a small restricter. I was just picking my brain thanks.
malik is offline
Old 03-14-2009 | 08:05 PM
  #5963
Tree's Avatar
Originally Posted by backyardracer
hi peoples
That is a stock Go Tech engine. You need to purchase any stock engine form a distributor or authorized dealer in your country. If you buy a stock Go Tech engine form someone in another country wether they are an authorized dealer or not, your mill will not be covered under warranty. If you are in the US, then I would recommend contacting 22Racer, VNMSGT, or Mr. Twister. They are all authorized Go Tech dealers and I am sure they can give you a lot better deal on a new engine than that ebay auction.
Tree is offline
Old 03-14-2009 | 09:27 PM
  #5964
Hi Adrian,well it is a bit of a mystery.When I stripped the motor down I found the rear bearing a little bit notchy but when I put the crank in again it spun freelyI`ll throw some bearings etc in and see what happens.
ben1970 is offline
Old 03-14-2009 | 09:57 PM
  #5965
losi_alaska's Avatar
Look what I scored on today from a friend of mine, it cost me 1 thunder tiger .61 airplane motor and a castle phoenix 60a esc. Everything in the go box is still plasti wrapped, come on D8T I can't wait Here is a pic
losi_alaska is offline
Old 03-15-2009 | 09:14 AM
  #5966
MrUnlimited's Avatar
Lucky bastard! How many ports? 3 or 5 ports?
MrUnlimited is offline
Old 03-15-2009 | 09:17 AM
  #5967
rearviewmirror's Avatar
That's definitely a 5-port race engine. I know because I just got one too!
rearviewmirror is offline
Old 03-15-2009 | 09:20 AM
  #5968
I already thought so. IT is still a lucky bastard!
Old 03-15-2009 | 10:46 AM
  #5969
bigmatt's Avatar
any know the crank case bearing measurements for go tech 5port? fr/ rear. I want to put in ceramic.
bigmatt is offline
Old 03-15-2009 | 10:47 AM
  #5970
ace921000's Avatar
freaking lucky lol. im looking for a new 5 port one.
ace921000 is offline
