Go-Tech Engines Thread
#5926
cheers grizz1 thats just what I needed..I think what I might do is track down a set of those ofna pipe tuning extenders and try fitting them to my 2047 header...in case you haven't come across them look here http://www.ofna.com/pipes-acc.html
#5927
the The 0801 is FEMCA approved , that means it can run .
#5928
Remove HSN completely from brass reciever
Flush the HSN by blowing into the pressure line
Clean the needle and replace
Whenever an engine goes from rich to lean like this its usually a carb obstruction .
Cheers MM
#5929
Now on to Modded mills, the guy who is getting his mill modded should have an idea of what he wants out of the particular engine. He should communicate wether its going into truggy or buggy which pipe he will be using ect to who ever the modder is and then the modder should know which route to go with his work. Massive Mods I am shure is awesome just look at peoples sigs there are lots of guys on here with MM on thiers. Speaks for itself, I want to try 1 of his my dam self. I am happy with my PTM. And Powerhouse knows his stuff to I have seen his work in action. Before I die I will have 1 from everyone LOL. I even had a AB mods P3 .28 back in my MT days.
#5933
If its not alot you will be ok. But take the flywheel off and spin the crank with your hand and see if the inner race ONLY spins try it a few times if the seal doesnt spin along with the race the bearing is still okay. If it is the stock bearing that went through break in and has 4-5 gallons on it you may want to replace it. Have you changed your rod at 2-3 gal? What I do is break in run it to 3 3.5 gal strip and change to TKO's front and rear new rod and clips at least, you most of the time can get away with the factory pin. But if you have no leak symptems your okay for now but start getting the parts i mentioned, TKO's arent a must but are nice to have and really the same price if not cheaper than stock bearings so what the hell right.
#5934
Hi Guys,was running my stock 7 port in buggy at recent North Island champs in NZ.Motor was hauling as usual until I went over a jump and heard a noise and flamed.
Pit man had a look and the crank pin had snapped off clean as.Rod,sleeve,piston still mint
Stripped motor and even bearings smooth,any ideas why this would happen?By the way motor is gen4
#5935
It was sitting for a few days with the tank empty. i took out the flywheel to change it and found some dirt caked on the bearing. when i went to wipe it out. a little while later it looked to be that a little bit of fuel starting seeping out of it. wiped it again then no more...what are the simptoms of a leaky bearing. i have only gone through a gallon on the engine
#5936
Stripped motor and even bearings smooth,any ideas why this would happen?By the way motor is gen4Put it down to bad luck I guess. When you replace the crank get one of the new Gen 5 cranks. They slip straight in and do enhance performance.
Massive Mods in Aus has them if you canīt get one local.
http://www.massivemods.com.au/produc...roducts_id=106
Contact Paul Fey here in Auckland first. He may well be able to help you.
#5937
Hi Grizz,showed Paul and Adrian at the race and they were surprised too
Paul is going to get me a gen 5 crank.I`ll thro another rod and bearings in and let her rip again.I have a 5port waiting in the wings if this doesn`t workout.
#5938
#5939
I should have been there myself, but work and finances dictated otherwise.
Trying hard to make it to the Windy 500. Might catch up with you there
2Likes
